For Sale/Looking For => Parts for Sale/Wanted => Topic started by: abnkeis on September 06, 2011, 06:07:41 pm
I have one pump that I took off my running Jetta and stored for a couple years now. $100
(http://www.freeimagehosting.net/t/2eb05.jpg) (http://www.freeimagehosting.net/2eb05)
****SOLD****I have one pump that the main seal started leaking. $50
(http://www.freeimagehosting.net/t/0407c.jpg) (http://www.freeimagehosting.net/0407c)
****SOLD****I have one pump that has the head off and most parts with it. $25
i have a 93 td golf. Would like to know if any of those would fit.
they will ALL FIT.. but how much modifying are you willing to do?
none of them are a bolt-on-and-go affair..
the only pump that will swap on your car with no other work, is the pump specifically from an AAZ engine..
It would help immensely if the OP would provide some details on each pump.
Pics added, hope that helps with questions. I used them on my 91 TD.
PM'd
Why did you take your pump off your jetta
I took it off to rebuild the motor, but decided not to rebuild and instead part everything out.
What year is that jetta or is that the OE that came on the car? TD?
Do you have the IP part #?
-Corey
-Corey
Sorry for the delay in responding.
I had the pump on my 91' TD Jetta, but had bought the IP from a guy shortly after he had had it rebuilt. I probably only put a few thousand miles on it before I tore the motor down for a rebuilt that I never finished, hence the reason it is for sale on here.
The numbers on the IP are as follows:
NR 0460 494 135
VE R 134-2
068 130 1090
1144 354 377
Thanks,
Dustin
