Engine Specific Info and Questions => IDI Engine => Topic started by: wdkingery on September 05, 2011, 07:40:28 pm
Title: Opinions on this lube here
Post by: wdkingery on September 05, 2011, 07:40:28 pm
Sorry I didn't know where to post this so I stuck it here.
I can get this for cheap.. But is it of any value??
 (http://img43.imageshack.us/img43/9271/imag0356az.jpg) (http://imageshack.us/photo/my-images/43/imag0356az.jpg/)
Uploaded with ImageShack.us (http://imageshack.us).
Title: Re: Opinions on this lube here
Post by: nathan_b on September 05, 2011, 08:13:12 pm
Well, if you want to run an electric pump and have a separate oil circuit and reservoir  for your turbo probably would be great.
For a combustion engine, I wouldn't dare put it in.
Post by: R.O.R-2.0 on September 05, 2011, 11:40:15 pm
yea, its for turbine engines that turn 30k rpms or more.. im sure its thin as hell, so it can flow thru the bearings at those speeds..
im with nathan, no way i would EVER put that in the crank case of my engine..
Post by: silentdub on September 06, 2011, 01:33:02 pm
I didn't see any weight info on that. I am sure that there are better oils with more information.
Post by: rabbitman on September 07, 2011, 12:21:08 am
I was flying in a bell 212 a couple months ago and there was a sticker on the side of the chopper that called for that oil. I'd never use it in anything but a turbine.
Post by: clbanman on September 07, 2011, 09:35:47 am
As mentioned, it is a mil spec oil that is not for our engines.  Per BP's specs, it is a 3 cSt synthetic lubricant, and kinematic viscosity at 40 degrees C is 12.46 cSt.   By comparison, Mobil 1 synthetic diesel oil at a 5W-40 grade at 40 degrees C has a viscosity of 97.9 cSt.   (Higher number is "thicker".
