General Information => General => Topic started by: srgtlord on September 05, 2011, 07:54:35 am
Title: Can a 1.6 fit in a mk3?
Post by: srgtlord on September 05, 2011, 07:54:35 am
How easy would it be to drop in a 1.6 from an mk2 into an mk3?
Title: Re: Can a 1.6 fit in a mk3?
Post by: burn_your_money on September 05, 2011, 08:32:05 am
Easy except for the power steering lines/pump, but they aren't that tricky. Oh and a minor bit of electrical but that depends what year mk2 you are talking about.
Post by: 8v-of-fury on September 05, 2011, 09:04:09 am
Is it a turbo diesel? I would never swap a non turbo 1.6 in to an mk3.. Not even an mk2 to be honest. 50hp is wayyy to low for anything heavier than a rabbit or early jetta.
A 1.6TD might be ok if you modified it, but stock I think you'll find it slow and boring quick in a heavy car. Even a 2.0L aba is kinda boring slow in a mk3.
So basically, unless you plan to hop it up I wouldn't advise it.
Post by: nathan_b on September 05, 2011, 09:24:07 am
here is how I see it, 2.0s are capable of 30mpg consistantly.
1.6td in a mk3 tuned to the same level of performance is maybe worth 35mpg. and thats pushing it.
so, does is an engine swap warranted for a 5mpg increase?
or you could buy a great shape 2.0 motor for $150, if your motor is bad..
Post by: burn_your_money on September 05, 2011, 09:44:26 am
Or you could install the 1.6TD and just drive it, not like you stole it an enjoy 40+ mpgs. The transmission you use will play a huge part in how the car feels
I've seen a 1.6na in a mk4 Jetta so this isn't that bad :-X
Post by: nathan_b on September 05, 2011, 09:59:42 am
its also illegal and will never pass emissions with an older engine in a newer car.
Post by: burn_your_money on September 05, 2011, 10:08:20 am
That depends on your state though right? Do diesels even have emission testing in most states?
Post by: 8v-of-fury on September 05, 2011, 10:18:27 am
Don't think they give a crap about diesels in ontario.. Pretty much fair game up here in the GWN.
Post by: nathan_b on September 05, 2011, 11:28:20 am
OP is in Massachusetts
Post by: CRSMP5 on September 05, 2011, 01:17:40 pm
hey ive been runnign 1.6td in b3 passats since 02... i do not have emission issue here... also my wagon is a 90 so in theory.. they made a 1.6 diesel that year...
to be honest.. it runs really good.. 70-80mph fully loaded with 40mpg is not uncommon and 36 around town is no issue..
now in 01 when i went to pick up the 83td jetta my engine came from.. from madison wi at that, i took my 83td coupe to pick it up.. with a 2nd driver.. ill admit the new td was faster.. had many miles of drag racing thru toll booths and such to know there was a huge differance in how the 2 ran.. so with that.. it is stock no mods still.. but one of the better runners
so yes it can be done..
Post by: R.O.R-2.0 on September 05, 2011, 02:15:17 pm
i know oregon and washington dont give a SH## what motor is in what car if its a diesel.. they ARE emissions exempt AFAIK.. idk if cali even tests the pre-TDIs..
and Bryan has a mk3 with a 1.6TD in it (with a sweet air to water intercooler setup).. but he is in canada, so i doubt he had to deal with anything besides passing inspection..
Post by: bajacalal on September 05, 2011, 08:17:54 pm
Technically, it's illegal at the federal (EPA) level, to put an engine into a car that is newer model than the engine.
However, not all states choose to enforce this and it's not something the federal government really seems to enforce either.
As far as Canada is concerned, I have no idea.
I would say that a non-turbo 1.6 in a mk3 would be so slow that it would be unsafe, given modern traffic conditions and the speeds at which other traffic would be traveling by comparison. A 1.6TD might be an option as there are other reasons than fuel economy alone that one might prefer a diesel engine.
Also, ROR, California does not currently test diesels 1997 and older. But, you would have to convince them to change the "G" on your title to a "D" to become smog check exempt if you do swap from a gas to a diesel. I've heard confliciting stories of that you simply ask them to do so all the way to having to go to a thorough inspection of the swap. They have, or at least had a program to certify cars with swapped engines for the correct emissions regime and they knew pretty well what to look for that wasn't legal, but mostly they were looking at people swapping 350s into Camaros and all the rice rocket Japanese stuff.
Post by: 8v-of-fury on September 05, 2011, 09:04:35 pm
I painted and diesel swapped my car, took the ownership that was in my mothers name.. and without any identification or proof of owning the vehicle got a new ownership printed off with the colour changed and fuel type changed in under 30 seconds.. Just setting themselves up for fraud i tell you ;) lol
Post by: bajacalal on September 05, 2011, 09:15:55 pm
They put the color on your car paperwork???  ::)
Post by: R.O.R-2.0 on September 05, 2011, 11:07:44 pm
yup, color, fuel type, amount of doors, weight.. yadda yadda..
Post by: 8v-of-fury on September 06, 2011, 07:35:28 am
They don't in Cali?
Post by: maxfax on September 06, 2011, 07:51:22 am
For all the other goofey crap in Pennsylvania, registration is cake..   Only things listed are Year, Make, Body style (NOT MODEL), and Vin..  Emission rules vary by county but most are just visual...
Post by: RabbitJockey on September 06, 2011, 02:38:23 pm
i think it's a nice swap for us in the states since we never got the aaz, mk3s are cheap and easy to get parts for, and they ride nicer, are quieter inside, they're nice daily drivers.  i'm sure a 1.6td would have no trouble moving one around.  malone had his franken engine in a mk3 golf two door, he said it was faster than a chipped vr6 even... but that was a very ported 1.6 with aaz head, pd130 intake, awic, and gt20 turbo.
Post by: vanbcguy on September 06, 2011, 07:43:16 pm
Jezzie does just great with her 1.6TD.  She was originally an AAZ car so there are no emissions issues - the 1.6 happily passes the tailpipe test here in Vancouver.
The AAZ and the MF are pretty darn close power-wise in stock form, so an MF with some minor tweaks will have just as much power as the AAZ at least in the upper range.
Post by: malone on September 09, 2011, 12:11:49 pm
Agreed. The MK3 also has better aerodynamics than all other generations (not sure about MK6). I'm finally finishing a new MK3 daily driver soon, after having driven my MK5 for 5 years. The MK5 is fairly reliable car but it's heavy and I'm getting bored of it (it's an auto). I also dread the potential DSG/flywheel and PD camshaft replacement costs down the road.
Post by: malone on September 09, 2011, 12:12:25 pm
Correct, but the AWIC wasn't even hooked up (no water circulation) so I basically ran intercooler-less. It was also smoke-free so it still had untapped power potential with an injector pump upgrade and intercooler. I miss that motor! My only complaint was lots of white smoke during a cold start.
Post by: RabbitJockey on September 09, 2011, 04:40:16 pm
didn't dave clear up the white smoke issue once he had put it into your jetta?  and also i was reading an old thread about the flow mods dave had done to the deck of your head, can u share anymore info about that?  was there much loss in compression from it?  you two are the like the idi gods of the americas in my book haha.
Post by: malone on September 10, 2011, 12:31:22 am
Here's a description of what Dave did to the deck of my head:
Here is my attempt at Paint, straight up KG style. :P
(http://i23.photobucket.com/albums/b382/dvst8r/Deck-mod.gif)
The Red circle is the the exhuast valve, the Blue one is the intake valve, the grey area's on either side are the area that has been relived. Of coures in real life they have uniform shape and size, as well as, they have a slightly differn't overall shape, size, ect..., but it will give you guys an idea. As Dave said earlier the relief is about .25mm-.5mm deep.
Post by: RabbitJockey on September 10, 2011, 06:04:05 am
thanks malone! so it would have been more like this actually?
(http://img.photobucket.com/albums/v306/Trev0rbr/mlt.png)
