Engine Specific Info and Questions => IDI Engine => Topic started by: 92EcoDiesel Jetta on August 02, 2011, 04:22:28 pm
Anyone know the best way in pulling the injection pump shaft seal please post pics of the tool you use and tips and tricks. Is there a special tool for such a small seal? The shaft is 17 mm diameter and the seal is about 1/4 inch wide.
notch an old flathead screwdriver on the side so it becomes a small pry.
Works a charm.
Works a charm.
What are you prying against? More details please! Any pics or videos of the proedure?
OK I figured it out! The crucial thing is to support the screwdriver so it is not prying against the seal itself! I used a big box wrench.
(http://i1183.photobucket.com/albums/x480/Ecodiesel92/Photo_080311_001.jpg)
Here's what my modified screwdriver looks like. A bit out of focus. A long screw driver helps with leverage. The one I used is about 12"
(http://i1183.photobucket.com/albums/x480/Ecodiesel92/Photo_080311_002.jpg)
Cleaning up the shaft sealing surface before the new seal goes in.
(http://i1183.photobucket.com/albums/x480/Ecodiesel92/Photo_080311_003.jpg)
Are you using the Greesel compatible seal for your new one ?
You mean Viton? No they're BNR which should be ok.
