Engine Specific Info and Questions => IDI Engine => Topic started by: entuzijast on January 29, 2006, 12:21:14 pm
Title: A question....maybe silly, but...
Post by: entuzijast on January 29, 2006, 12:21:14 pm
I would like to get 90 - 100 hp, and I know that "unscrewing" the pump it will get me up to 90 hp (ofcourse with intercooler)...But, my car is a daily driver and I wanna keep the mileage...
So, I was wondering how about to do ONLY the governor mod...I assume that mileage will stay the same until the point where the governor should kick in, but, will I get the desired 90 - 100 hp?
I forgot to mention it is an ECO with TD pump... :)
Post by: 935racer on January 29, 2006, 02:38:34 pm
The governor mod alone isn't going to get you 90-100hp, you will need to increase your boost and fuel to match that. Even on well tuned diesels, economy usually isn't too bad if you keep your foot out of it, but thats pretty hard to do when you have that extra power there :D
Post by: RabbitJockey on January 29, 2006, 03:45:23 pm
i'm curious how much it takes to get 100hp out of a 1.6TD with an intercooler.  could this be accomplished just by cranking up the boost and fueling(with out doing the gov mod but with the timing set to 1mm)  what kind of torque would this produce
Post by: 935racer on January 29, 2006, 03:54:58 pm
I highly doubt you could hit 100whp without the governor modd, unless you have some serious LDA mods and a bigger head/plunger, camplate etc.
Post by: RabbitJockey on January 29, 2006, 04:03:18 pm
ok then. well with the governor mod, 1mm timing and more boost more fuel, is 100hp achievable?
Post by: 935racer on January 29, 2006, 04:40:18 pm
Yep
Post by: RabbitJockey on January 29, 2006, 05:51:08 pm
i'll have to have a little talk with my dad about his 85 jetta td mmm.  been trying to get him to give it a little performance since he first bought it for $200
Post by: texaseric on January 29, 2006, 06:37:03 pm
Post some shots of your car. I've never seen a Cabby/diesel.
--TexasE  :?
Title: texaseric...who on this post has a cabby diesel
Post by: RichMason on January 29, 2006, 11:32:51 pm
I don't see anything that indicates someone here has a cabby diesel.  I'm doing one...did you post in the wrong place?
Best,
Rich
