Engine Specific Info and Questions => IDI Engine => Topic started by: Alcaid on July 18, 2011, 04:18:30 am
Finally, a trusted vendor supplies H-beam rods for our 1.6TD builds at a decent price!
If you're not familiar with Rosten-Performance, check out the TDIClub forums.
(http://rosten-performance.com/images/rods/h_beam_rod_vwaudi_16td.jpg)
- 136mm center - center
- 24mm small end with bronze bushing
- 50.6mm big end
- 2 piece forged from 40CrNiMo steel
- comes with ARP 2000 bolts and assembly instructions
- shoot peened and heat treated
- weight is 560 gram included bolts, with a tolerance of +- 1gram
- Designed to use TDI rod bearings which are far better than the 1.6TD
- Price complete set: 350.00 €
www.rosten-performance.com
I'm in no way affiliated with this vendor, just giving you guys a heads up :)
Thanks, good to know 8)
I have been waiting for these to appear. Thanks for posting. Hopefully these won't just be a limited run item.
had to be after I quit driving a VW...
oh well, good to see that they are being made at last!
-Owen
