Engine Specific Info and Questions => IDI Engine => Topic started by: dieselherb1 on July 04, 2011, 07:42:26 am
Just replaced head gasket(milled head) installed GT15 turbo(spools quicker) Thought I had the timing right(.030) but smokes alot at idle and you have to rev the engine to move the Caddy or engine stalls. Can the timing still be off that much? Or why else?
You have it timed to .030"? That's way low..
That is 0.762 millimeters, and that is at least 0.12 mm to low from the lowest stock setting.
Re time the motor to at least 0.037" and your problems will be solved, for a little more performance with the exception of more NOX (who cares ;)) you could bump the timing up to 0.040-0.041" :D
This
Problems with not enough fuel getting to the Inj pump will do the same thing..
When timed properly, yes it could be a culprit.. But the fact that he has stated it is timed to 0.030" is the problem. The timing is very retarded, I'm actually surprised its running so low!
Agreed on the timing.
As an aside, why are we talking inches when we are talking timing? Is it common for people to use sillymeasurement on this board?
I'm Canadian, yet I still have an Imperial gauge LOL
