For Sale/Looking For => Parts for Sale/Wanted => Topic started by: arsenicpants on June 20, 2011, 10:23:42 pm
parting my TD with ~70,000 km
I'm not crazy about shipping, sorry
1.6 block has approx. 70,000 km on it, but needs new rings. cylinder walls still look smooth. original TD block. includes complete bottom end. pressure plate & clutch not included $50 obo
(http://img.photobucket.com/albums/v222/ArsenicPants/TD_block.jpg)
TD Head off of the same motor (70k). includes absolutely everything minus the exhaust manifold & turbo. intake manifold has had the blow off valve deleted. mercedes injectors. I believe it's been mildly ported. valve cover studs have been modified to accept the re-usable rubber G60 gasket$150
(http://img.photobucket.com/albums/v222/ArsenicPants/TD_head.jpg)
TD pump. recently rebuilt, and off the same 70k motor. has been tuned to basically throw fuel at the motor, and blow black at low RPM. great pump, no leaks, very strong $100
(http://img.photobucket.com/albums/v222/ArsenicPants/acfff6c0.jpg)
I've also got a very low km water pump, replaced less than 5,000 km ago, and a toilet bowl downpipe in very good shape $20 for the water pump, downpipe free
im in langley and wouldnt mind grabin the water pump off you.
could i grab a number and a good time to call.
thanks, kevin
thanks Kevin!
let me know if you need anything else :)
Do you still have the block?
