For Sale/Looking For => Parts for Sale/Wanted => Topic started by: CRSMP5 on May 21, 2011, 09:16:35 pm
Title: 81 1.6na jetta diesel coupe... ne ohio $1500
Post by: CRSMP5 on May 21, 2011, 09:16:35 pm
http://www.crsmp5.com/81_coupe/81_coupe.htm is a place with lots of photos and descriptions..
the good.. rebuilt 1.6 na that runs strong and has started every cold day this past winter..
new front brakes..
200mm 90 jetta rear brakes
if you need a pos cheap car to drive this is it.. why lock the doors.. nothing in it to steal..
rear parcel shelf has never been cut.. probally worth more then the car..
i do nto have to sell it.. just see no reason to keep it.. so might aws well sell it to add stuff to BURNT TOAST
Title: Re: 81 1.6na jetta diesel coupe... ne ohio $1500
Post by: DieselBalz on May 21, 2011, 09:41:32 pm
How bad is the rust? Looks like there are a few spots from the pics, but how is the underside. Also, is the roll cage welded or bolted in?
Post by: Quantum TD on May 21, 2011, 11:54:07 pm
I like the historical plates. Looks like the car is about to become history within the next 2 years  ;D
Post by: CRSMP5 on May 22, 2011, 01:00:35 pm
rear is welded.. front is bolted incase dash has to come out..
needs a bottom clip.. :D its got 2-3 seasons IMO.. i always intended to find a cabby and build a real coupe targa from the roof of this.. kinda like eurojettanut's wagon project but the other way.. aka move trunk over back seat area
the worst rust is the right rear axel point.. its flaking.. no cracks.. but it is rust waiting for the right set of rr tracks or big pot hole.. is it rusted thru.. no no hole.. but a big flake of rust has fallen off..
the rockers have gotten worse.. not a place to jack this from.. only suspention points for that..
hey now those historical plates are great... 25$ 1 time fee for life... i pay my yearly road use taxes on my b3.. can only drive 1 at a time.. why pay same tax 2x..
burnt toast project got set commin.. :D
besides the rear parcel shelf being uncut... the windshield is the ORIGINAL with goofy epa break in sticker still on it.. i did replace the seal when i put it together originally.. it does leak once in a while.. right at the top in the middle.. the rain drop seems to fall right on your knee
this is my 4th summer with it... have run 3 winters.. its the perfect example  of why lock it there is...
i still need to rekey it.. so will do you a favor.. ill key it to your other vw so they share a key.. :D my key fits all mine.. so easier to rekey this vs the others.. else ill key it to the toaster key/ignition... ill even teach you how too if you have never seen it done..
Post by: R.O.R-2.0 on May 22, 2011, 01:09:32 pm
i love how easy it is to re-key a VW car.. i re-key all my cars with a file.. just slip said key in lock cylinder, and then file the tumblers down flush like they are supposed to be. then 2 keys work with the car.. the original, and the key you changed it to..
Post by: CRSMP5 on May 22, 2011, 08:44:47 pm
no i have a assortment to do it right...
ignition is ignition...
glovebox is glovebox.. that one is hardest as the piece that fits the key had many different style blanks.. and 1 out of 10 seems to fit..
doors/trunk share..
ive got a ignition to put in it.. just need to redo doors/trunk.. unless buyer wants to use his key..
