Engine Specific Info and Questions => IDI Engine => Topic started by: BillyWillicker on March 25, 2011, 05:41:31 pm
Title: Was reading that some were looking for good valves.
Post by: BillyWillicker on March 25, 2011, 05:41:31 pm
I saw here that some of you were looking for nice valves for mechanical heads for thier high power IDI's.  I found the perfect items.  Being an audi guy I tripped over these.
http://www.034motorsport.com/engine-components-audi-i5-10vturbo-exhaust-valve-set-wx-urq-34mm-nitrided-stainless-with-install-parts-p-18555.html
http://www.034motorsport.com/engine-components-audi-i5-10vturbo-intake-valve-set-wx-urq-40mm-nitride-stainless-with-install-parts-p-18853.html
The intakes may be a bit too big, but the inconel exhausts should drop into a stock seat!  This is a SUPER deal at the price thier offered with what they come with.
Hope this helps out!
Oh, and what are the stock valve diameters in a 1.6 IDI mechanical engine?
Title: Re: Was reading that some were looking for good valves.
Post by: RabbitJockey on March 25, 2011, 05:54:14 pm
i believe the stem length is different on those
Post by: BillyWillicker on March 25, 2011, 05:56:12 pm
pretty sure its not, however it may be different.
Post by: rabbitman on March 25, 2011, 09:37:16 pm
Stock 1.6D valves are 34mm intake and 31mm exhaust with 8mm stems.
Post by: rabbid79 on March 26, 2011, 04:01:36 pm
This is 100% correct.  The diesel valves are ~105mm in length.  The gasser valves are ~91mm in length.  Part of this has to do with the head of the diesel being flat, so the valve has to be longer.  On the gas engines, with part of the combustion chamber in the head, they're shorter.
Post by: RabbitJockey on March 26, 2011, 04:40:02 pm
also solid lifter and hydro lifter have different length valves
