For Sale/Looking For => Parts for Sale/Wanted => Topic started by: the caveman on March 16, 2011, 09:44:19 am
priced for a quick sale here for a relative. 2002 Jetta ALH. This is the one i posted a question about damage that could happen if driven with no oil . Very ,very little metal shavings in the pan when pulled it. Replaced most of the bottom end bearings, even though they weren't too bad. Still has a clicking from the engine though. Either a lifter stuck and a valve hit the piston or the piston now has side wear. 1,2,3 cylinders have good compression -350-400, #4 is 300 lbs. No smoke after one minute , I just drove it home from the other side of town. Everything works. There is a fuel temp sensor DTC . I have already replaced the sensor and checked the plug near the IP , but fault still comes back. Car has been driven for more than a year with the MIL on, and when checked with Vac-com, ,it's in spec. I will look into it more, but doesn't have an affect in performance. Also windshield cracked. Not a great deal,but a good 100% solid car . asking $2000 as is. Black with black leather. call for more info. Marc 514 893 3013
