General Information => Troubleshooting => Topic started by: silvertdvw on March 02, 2011, 12:30:11 pm
My car is leaking a lot of oil out of the two little holes near the top of the front crank seal carrier. Why is it leaking??? ??? it makes a huge mess because it sprays oil directly onto the belts and the higher you rev it, the more oil sprays out as the oil pressure builds. I have approx 12,000kms on a complete rebuild and it just started to leak.
(http://i562.photobucket.com/albums/ss69/silvertdvw/020-1.jpg)
Is it for sure leaking from the holes, or could it be slinging up there from a leaking front seal? My best guesses on that would either be some variety of issue with the housing itself, such as a crack, or the gasket isn't doing as it should.. Have you tried snugging the bolts a tad more??
its fixed now it was just the gasket
Had a similar issue with my int shaft seal. Eventually i figured out that it was leaking from the oil galley plug tirhg above the int shaft seal carrier. That was a *** to change out with the engine in the car.
