General Information => General => Topic started by: 8v-of-fury on February 25, 2011, 09:19:57 am
Title: Front tires were on fire.
Post by: 8v-of-fury on February 25, 2011, 09:19:57 am
The car in question, a 1994 Jetta 2.OL gas.
Gf's sisters car (yes I have infected everyone with the vw lust lol). Yesterday she phones me up and says hey, so my front tires were just on fire. Apparently she pulled over because she saw smoke (good girl) and then saw flames coming from inside the rims. Doused them quick and phoned me.. I was at work so I had my bro take her wheels/calipers/pads everything off and have a good look around. One thing he noted to me was that there was a significant lip on the rotor and the pads look pretty worn... Normal you say? These pads/rotors have less than 5k on them. And already a noticeable lip? Either she rides em like a mofo coming to a stop, or the calipers are seized. My parts guy and air cooled guru suggested he thinks it was the bearings starting to cease up.. I support that idea except for even now (after the fire and obvious mad heat) there is no tell-tale bearing failure noises. Personally I think it was the brakes, but has anyone heard of pads catching fire?
Thanks guys
Title: Re: Front tires were on fire.
Post by: truckinwagen on February 25, 2011, 09:38:10 am
yep, I certainly have heard of pads catching fire, but only when stomped hard and long.
I do not know this girl, but I know my sister, who asked me to take a good look at her car that was "shuddering and shaking when I brake"
turned out there was nothing wrong with the car other than the fact that she was stabbing the brakes so hard and late that the ABS would kick in on dry pavement in town(takes ALOT of foot to do that)
of course it could be the wheel bearings too, as they begin to wobble the rotor/pad alignment goes out, wearing the pad and rotor very fast, they also make lots of heat.
but if it were bearings, I would expect there was lots of noise for a long time before anything caught on fire(same with stuck calipers, should make lots of bad noises before catching on fire)
-Owen
Post by: 8v-of-fury on February 25, 2011, 09:57:31 am
That's the thing... No noises of any kind. I have driven and ridden in the car many times. The car made a 30 min trip yesterday (town to town) and they were hot enough to catch fire?
Now I have only done bearings on an mk1, never an mk3... How do they come out?? I think replacing them anyway might be a good thing, as they're probably stock.
I wonder what can I look for to point me to a failing caliper? Watch its motion and see what happens?? See if it extends and retract smoothly? With the pads and rotor in place of course.. Don't wanna rip the seals... Lol
Post by: R.O.R-2.0 on February 25, 2011, 10:40:20 am
if the bearings are still tight, leave them alone, the bearings are a PITA to replace..
im willing to bet that its a bad master cylinder or a bad caliper tho, because i drove a wheel bearing soo bad that the front hub about came out of the knuckle..
and brake pads do indeed catch on fire.. my buddy and i caught his brakes on fire one day.. we finished a trip that usually takes an hour and a half, in 22 minutes..when we got to where we were going, there was smoke rolling, then i noticed one of the plastic hub caps starting to melt!
Post by: Quantum TD on February 25, 2011, 12:11:25 pm
I"d replace the rubber hoses too. They're probably melted anyways, but sometimes they degrade internally and the calipers can't release the fluid pressure. There's a good amount of pressure sending fluid to the calipers, but not so the other way.
Post by: Dakotakid on February 25, 2011, 01:30:30 pm
I think you will find that the problem is simply the way the dippy little beeotch drives! (There....THAT statement will keep the legal team busy for awhile!)
Post by: theman53 on February 25, 2011, 01:34:26 pm
That is my mechanical guess. The rubber falls apart inside and acts as a check valve. I bet it has been doing it a long while to wear the brakes in 5K. And since it is rubber it sometimes isn't 100% all the time.
If not that I say x2 to Dakotakid :D
Post by: 8v-of-fury on February 25, 2011, 02:54:21 pm
I told her the other day and I quote "Your head, it is full of air". She didn't catch on too quickly lol.
Post by: macka on February 25, 2011, 04:36:33 pm
does she have the same last name as you? Cuz you can always call her Hollowhead H******
Post by: Baron VonZeppelin on February 25, 2011, 05:21:07 pm
I've melted a couple of hubcaps in my day.
Both times it was a bad/stuck caliper.
Hoses do sound like probable suspects tho.
Post by: 745 turbogreasel on February 25, 2011, 11:47:46 pm
On mine it was rust at the snap ring  preventing the master cyl from returning all the way.
Post by: RadoTD on February 26, 2011, 07:42:22 am
Is she hot?  :)
Post by: 8v-of-fury on February 26, 2011, 12:54:01 pm
Ok so I had a chance to look at the car today. Ripped both brake assemblies apart and inspected things. Everything was just dandy. Bearings tight and brakes were fine.
I bled both just to make sure it had some fresh fluid in it.. And then went for a drive. I got up to.. Let's say very fast.. And gaeared down to a stop.. Not using the brakes, and the rotors and bearing area were cold to the touch. Did a moderate to heavy stop from the excessive speeds to make my test completely conclusive.. And damn did they smoke.. Definitely not the bearing.. And I can't believe the airhead actually saw flames....
Post by: RadoTD on February 26, 2011, 07:54:32 pm
Possibly some sort of flammable liquid soaked into the pads and burned off? Something still left in there that you got smoking...
I think of replacing the brake pads either way, just to be safe
Post by: theman53 on February 26, 2011, 08:07:01 pm
I would say hose, caliper, or master cylinder. I would lean away from caliper just because it comes and goes, but stranger things have happened.
Like Rado said maybe oil or cv grease got into them and is wrecking the friction material. Maybe try a can of brake cleaner if all else looks good.
Post by: Runt on February 27, 2011, 11:46:32 am
Yep, it definitely sounds brake related.  I've seen it before, more than once.  Once the brakes get that hot, they need to be replaced, as you cook the binders out of the pad material, and make a mess of the rotors and caliper seals.  If you must, change just pads and hoses, but check, clean, and lubricate the calipers really carefully, and keep an eye on them.  Then dont be surprised if the calipers either seize or leak in the near future, or if the rotors start to flake off a layer about 1/16th of an inch thick.  Unless you are able to keep an eye on it, I'd seriously consider doing it all, rotors, pads, calipers, hoses, and possibly even master.  FWIW, I have had multiple rebuilt masters fail in the first couple months.  I will not use a rebuilt master on my own, and I pretty much refuse to install them into customers cars, too.  The ceramic pads (most of the premium stuff nowadays) work well, and dont seem to have as many issues, but I've seen way too many comebacks for noise complaints with them, even properly installed with a nice layer of anti-squeal.  If you can talk to the parts guys, I'd try to get a decent semi-metallic, and put up with a little more dust, and possibly more fade if they are really hot, given what I'm guessing about the owner.
As an aside, I had an f150 that I had the brakes glowing and smoking something fierce (might have been flames, I was afraid to look, they were lighting up the sides of the road!), towing a boat with no trailer brakes through a notorious peice of mountain road (duffey lake, for those who know it).  The only thing that put them out was the puddles at the bottom of the hill, which shatterred the pad material and cracked/checked the rotors.  I rolled the last 100km on rivets into the cracked rotors, real slow, but at 1:30 am in Mt. Currie I just wanted to get home.
Post by: R.O.R-2.0 on February 27, 2011, 01:21:04 pm
ceramic pads eat the rotors no matter what.. from my experiences atleast..
Post by: 8v-of-fury on February 27, 2011, 08:44:29 pm
they might be ceramic.. I recall buying a service grade for that car... coulda been ceramic...
Post by: 81 vw pu on February 27, 2011, 09:59:21 pm
Is this the same car that had a rear wheel fire last November?
Did it end up being a wheel bearing that time?
I'm thinking it's the master cylinder holding pressure on the system after the brakes are released.
Is the push-rod that goes from the brake pedel to the vacumn booster adjustable? I remember working on a car years ago
that the rod had somehow been adjusted too long and was causing a similar problem.
Your post from last November.
http://www.vwdiesel.net/forum/index.php?topic=27679.0
Post by: 8v-of-fury on February 28, 2011, 07:36:19 am
Yes same car, however that issue was resolved.. That time it was the lines holding the rears on after pedal was released..
This time the wheels spin freely as soon as you let off the pedal..
Post by: theman53 on February 28, 2011, 07:43:55 am
You never said if she was hot or not.
Post by: 8v-of-fury on February 28, 2011, 08:15:10 am
Lol, not hot. AirHead more like it :p
Post by: theman53 on February 28, 2011, 08:43:56 am
I would ask her to drive it for a day or two. See what is really going on if possible.
Post by: RabbitJockey on February 28, 2011, 03:15:41 pm
something interesting that happened to my brothers 16v roc, i think it was mostly due to a spent wheel bearing
(http://img.photobucket.com/albums/v306/Trev0rbr/DSCN0130.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/DSCN0131.jpg)
Post by: 8v-of-fury on February 28, 2011, 06:05:44 pm
wowwww. thats ridiculous... Kinda scary lol
