Engine Specific Info and Questions => IDI Engine => Topic started by: rabbitman on February 21, 2011, 08:04:04 pm
Title: Changing valve guides
Post by: rabbitman on February 21, 2011, 08:04:04 pm
I'm putting together my golf and measured the valve guide "rock" like in the bentley. Seven of the valves were .025-.030" (the bentley doesn't give a new spec). One guide, the #2 intake is at .055ish..........the wear limit is .051" :'(
I'm having problems finding a shop that will touch this head so I'm trying to decide if I should, 1) put it together and run it, and in the meantime collect valves, guides and the tools to change them myself if I can't find a shop that will do it.
2) Leave the guide alone and put new valves in (they have slight scratch marks, I can't feel 'em but they're visible),
3) or get new valves and guides. I really want to get this done and out of the shop though.
So will I even notice oil burnage? Can anything bad happen to the engine? What's your opinions?
Title: Re: Worn valve guide
Post by: CRSMP5 on February 21, 2011, 08:28:09 pm
you cannot just do that...
if you had the "proper tools" go for it.. but i doubt you do...
when you install new guids they will need a reamer run thru them.. no reamer you stand the chance of the valves locking open when warmed up..
you need to cut the valve seats.. this means also shortining the valves a titch (new or used).. having enough valve shims/tools to maybe take it apart a couple times to get the shims in proper tolerance.. you do not want the shims to be thin.. want them to be in the middle..
send it to a shop and just get them done right.. yea shipping will blow from alaska.. but the tools to do it right is far more expensive..
if you 100% trust your head.. aka no cracks or issues talk to myke_w get his head shop info and ship it there..
id ship it with cam removed and have it shipped back with cam removed.. do not ever ship a head with a cam in it.. too easy to tweek a valve which will let the head pop off in a bad moment of life..
Post by: rabbitman on February 21, 2011, 08:50:19 pm
I should've specified that this is a hydro motor.
I do have access to a valve grinder, I doubt I have a seat grinder though.
I don't have a press or the proper uninstall/install tool.
I'm thinkin' I'll just run it. The only thing that can go wrong is it might burn oil right?
Post by: truckinwagen on February 21, 2011, 08:52:20 pm
if the guide is too loose you could drop a valve.
not something I would risk with these motors.
I did not have a chance to look the head over really good, I thought it was in much better shape than that...
-Owen
Post by: rabbitman on February 21, 2011, 08:54:56 pm
-Owen
Yeah I would never have noticed it if I hadn't taken it apart for port/polish.
I'm lookin' at this tool, http://cgi.ebay.com/ebaymotors/VW-BUG-GOLF-ENGINE-HEAD-VALVE-GUIDE-INSTALLER-TOOL-8MM-_W0QQcmdZViewItemQQhashZitem439c5b17dbQQitemZ290386024411QQptZMotorsQ5fAutomotiveQ5fTools
Post by: rdezsofi on February 21, 2011, 10:38:43 pm
I have that same tool. Works just fine. Install a valve guide, and test fit a valve. If it's too tight, try another valve. I have about 120,000 on a head where I did the valve guides with no problem. The head originally had around 100,000 on it when I worked it over. I had a machine shop press new valve seats in, and I hand lapped the new valves. Much easier on a hydraulic head, as you don't have to mess with the shims. I have a collection of about 200 shims, and it's time consuming compared to the hydro heads.
If the shop doesn't want to mess with your head.....try disassembling the whole head and see if they will at least do the valve seats to a 45 degree angle. (Or preferably, press in some new ones.) Order yourself some new valves....they are not expensive....so buy quality ones.
Meanwhile, you'll probably just use some oil. Try not to go over 2800-3000 rpm with that loose valve, though. Baby it. As a side note, if it's using some oil and you get some blue smoke, it will take quite a while to clear up after you get the head done, due to the oil residue in the exhaust that will slowly burn off.While you have the head off, it's easy to pull the pan, change out the rod and main bearings and maybe a fresh oil pump. If you do that, it's worth measuring the bore while each piston is down.....often there's minimal cylinder wear, still within specs. If thats the case, you can pull the pistons, hon ethe cylinders and install some Goetz piston rings. You'll be good for 200,000 more.....
Post by: rabbitman on February 21, 2011, 10:49:43 pm
You did this on a diesel?
This shop was afraid heating the head to loosen the guides would make the seats would fall out and after that it's too iffy to run (he said). I'm sure he wouldn't want to install new seats.
This engine only has 63,000 miles and this whole issue is from the two-owners-agoz friend putting the t-belt tensioner on backwards and smoking the new belt.
Now that I think about it, I bet we do have the right valve grinding stuff for this engine, if the sizes are anything like the aircooled vdubs.
Post by: Mark(The Miser)UK on February 22, 2011, 04:12:30 am
So is this an n/a Golf?I would not change anything on the head.
The only valve out of spec is an inlet, and will have nothing travelling up the stem any how :o.
Any trivial scoring will serve to hold the lubricant.
A slack valve will still seat correctly/repeatedly.
I don't know why you would want to grind seats anyhow, as long as they seal:
Assemble head, and with head upsidedown pour kerosine on each valve head in turn when shut to check for sealing. Nothing else required other than:
  Perhaps change the valve stem seals, if they are not gripping the valve stems, and be sure you assemble them[push them on ] correctly. I think its an 11 or 12mm 12point socket.
Why would the head drop a valve with a slack sleeve?
Give me the money you are going to throw away, and if you get a dropped valve from that intake within 18 months I'll give you double your money back ;D
Post by: maxfax on February 22, 2011, 07:31:03 am
I've run some pretty sad heads.. For quite long periods of time too...  Other than maybe a touch more oil consumption (coulda been rings too) they actually ran quite well..  These were all NA's of course..   The exhaust valves were so bad on my last head they literally would just fall out with the seal removed..  Never measured so see how bad they actually were, there was no need..
I guess the real question would be, what are your intentions and expectations of this engine???
Post by: rdezsofi on February 22, 2011, 08:05:36 am
Yes, a 1.6 NA. The seats, valve guides and prechambers are simply a press fit. The guides are quite tight....they probably won't fall out by only heating the head if you tried! A worn guide on the intake side will suck some oil in at higher rpms, but being either cylinder 2 or 3 the problem won't be as noticeable. Cylinders 1 and 4 will suck more oil in around sharp corners as the oil pools there, reesulting in a large cloud of smoke coming out of a long sharp corner taken at speed. The biggest concern is if the head is flat. Ant more than .004 and junk it. Remember that if the head is warped, the cam is being held in a bent position. Milling the head still leaves you with a problem with the cam bearings being in line.
You can mill the head .002 or .003, but you have to remove the prechambers and then they have to be milled down the same prior to being installed.
Post by: R.O.R-2.0 on February 22, 2011, 08:22:25 am
some people knock the cups out, some people skim the heads with them in, some knock them out and fly cut the precup bore.
i dont think there is really a wrong way. but i would go with the fly cut precup bore personally..
Post by: RabbitJockey on February 22, 2011, 06:20:47 pm
yeah i think the right way to do it is to remove the cups, surface the head then skim the same amount off the top of the cups or the top of their hole in the head, then reassemble the pre cups are supposed to stick out a small amount to account for heat expansion
Post by: rabbitman on February 22, 2011, 07:35:05 pm
Some day I'd like to turbo it....... ;D, I have that euro vnt-15 that wouldn't boost on my rabbit that I'm gonna send out and get fixed (some day), and from what I've read the euro vnt shouldn't interfere with the rear mount.
I talked to the guy at aircooled engines plus about the guides and he said "just bang 'em out and bang the new ones in", haha. He also said heating the head to 200-220F would help loosen the guides without loosening the seats too much, 300F is the limit and after that things start getting loose.
I checked my available tools and found the guide reamer and all seat and valve grinding stuff in case I have to grind anything, then I ordered the guide tool on ebay.
I really hate putting a head on with stuff out of spec, I have the stuff and it's all apart so I guess I should do it right.
Post by: maxfax on February 22, 2011, 07:51:00 pm
That's typically how I feel about things, unless it's some POS beater that I'm just running into the ground...  By the sounds of things this one doesn't fall under "POS beater"..  You're this far into it, what's a little bit more??  ;)
Post by: rabbitman on February 22, 2011, 08:01:49 pm
This car is supposed to get me out of the "he drives a beater" class without getting a car that I really hate haha, I'll get a cushy newer car when I'm old and boring ;D. I want to get the rabbit off the road for a while and do some rust repair, fix some oil leaks and quiet it down a lot and I need another car that I like during that time.......I'm not planning to sell the golf afterwards though.
Post by: maxfax on February 22, 2011, 08:09:07 pm
HAHAHA..  Nice cushy cars don't have to be boring, but I gotta say I've had the most fun with beaters...
Post by: rabbitman on February 28, 2011, 09:30:49 pm
Well, I went and ordered a whole set of valves and guides from air cooled engines plus.
Post by: rabbitman on March 16, 2011, 03:39:57 pm
Well I found out I have valve and seat refacing setup, I'll need to get the proper size stones though since the ones I have for aircraft engines and therefore HUGE compared to what I need.
Post by: Mark(The Miser)UK on March 16, 2011, 04:53:59 pm
Well I found out I have valve and seat refacing setup, I'll need to get the proper size stones though since the ones I have for aircraft engines and therefor HUGE compared to what I need.
Clearly lots of money floating around  Alaska :o
Why do you need to do anything other than lapping a new valve in with coarse and fine paste, and a childs arrow with a rubber suction cup on the end?
Post by: rabbitman on March 16, 2011, 05:05:06 pm
I talked to the guy at air cooled engines plus and he said valve grinding compound went out with the model T and all lapping does is remove 100,000 miles from the new valves.
So the best method is perfect valves (which I assume these will be) and perfect seats and theoretically they'll seal perfect. The only problem is I have to make the seats perfect on my first try.........
Post by: sdwarf36 on March 16, 2011, 06:30:33 pm
The reason the guides wear is there are very short in design. Gas or diesel-its just how the head is.
 I have every machine shop tool availbile at work-and to r+r the guides in my head-I used a proper sized guide driver + hammer.  Thats all. They aren't in there THAT tight. I do throw them in the freezer for a while before installing them. (I may have also run the head thru the parts washer to warm it up some--but were talking only 120* or so.)
 For heads that are known to have really tight guide fits, I'll drill the guide out 1/2way down to larger size-and then hammer+ drift it out-so its pushing from the middle. (it saves the end of the guide mushing over+ screwing up the hole.)
 Odds are good that you will have to ream the guides out slightly-but even if its only .001 or .002 you need, you still gotta do it. And there is nearly zero chance that the the valve will seat same as the old guides-so you WILL have to cut the seats.
 I'm suprised the machine shop is scared to work on your head. Short of having pre cups where the spark plugs would be, this head is the same as a gasser-and have been around for almost 40 years. This is run of the mill stuff-nothing fancy at all.
 If you want to box it + ship it across country, we can do anything you need to do on it. We aint scared.  ;)
Post by: rabbitman on March 16, 2011, 07:12:42 pm
I would've liked to have someone else do it but after shipping it around and then paying labor cost will add up way to fast.......and after re-remembering that we have seat grinding stuff here I'm kinda excited to do it ;D.
This http://www.cylinderheadsupply.com/sisthdvasegr.html is really close to what we have except for the selection of wheels and pilots are probably different.......and ours is way older.
Post by: Mark(The Miser)UK on March 17, 2011, 08:15:50 pm
Interesting how modern technicians would think that grinding in with paste would take more flesh off than machining... :o
 Apart from removing the hollows from pitted valves, due to valves burning due to not shutting correctly
[I've never seen this on these engines]; using paste, is merely to ensure, and reveal that a brand new pre cut valve [aren't they all these days] seals all round, by the finest of seal edges
[Remember a valve should never be machined to the same angle as the seat].
The pencil thin seal area ensures a perfect seal, but if you are looking at  a 3mm width seal, [as revealed by the 'matting' effect of the fine paste], then the technician has spent far too long lapping;  perhaps erroneously thinking wider the better.
Minimal fine paste lapping is essential to ensure that machining has created a seal for yesteryear, today or tomorrow, PERIOD.
Any technician, engineer, or amateur who thinks otherwise, is  regrettably, out of the loop of maintenance, and merely a part swapper.
If there is a lathe operator who can take off less flesh from a valve head than fine lapping does then I'm impressed. If you think about it a lathe can only remove a layer from a plane, not a point
Post by: rabbitman on March 18, 2011, 11:29:23 am
So if a guy has new valves and installs new guides then the seats must be ground to make it all line up again. If after doing that the valves seal good then there's no point in lapping them at all, I think accuracy today is good enough that it everything should seal fine.
The other thing is lapping removes material from the valve and seat, grinding and polishing the seat only takes material from the seat without putting a ring in the new valve.
I'll find out, if I do all this and can't get a good seal I'll lap them a little bit.
Post by: Mark(The Miser)UK on March 18, 2011, 12:58:41 pm
I agree it should all fit snug, but then again the head itself is still old and may be twisted around the guides slightly, and the seats could be out slightly due to years of being thumped at high temp.
A totally harmless check for sealing, is to use some metalworkers blue on each valve and seat, and rotate once and check for continuous line.
Also with valvesprings in, but not cam, drop some kerosine onto valve heads...
Remember it's purpose is to create a matched pair, just as the advocates here on lapping the old injector body onto a new nozzle helps [if not messed up] the body to seal. grinding and polishing the seat only takes material from the seat without putting a ring in the new valve.
Post by: rabbitman on March 19, 2011, 08:52:25 am
Yeah the guy did say to put that blue stuff on there and shut 'em and see were it's clean.
Post by: sdwarf36 on March 19, 2011, 10:57:25 am
If you dont have any machinist die-magic marker works just fine. And you are better off with just slapping the valve against the seat-or rotating the valve slightly-it will show if it is seating all the way around. If you turn it a full lap, the high spot (if there is one) will make the mark everwhere-you won't be able to tell if you are getting good contact all the way around.
Post by: R.O.R-2.0 on March 19, 2011, 11:40:05 am
supposed to fly-cut the bores after you surface the head with the cups out..
Post by: Mark(The Miser)UK on March 19, 2011, 03:01:38 pm
Ah good pont, you got me there ...  ;D                                                    Except you put marker on both faces 8)
Post by: rabbitman on March 25, 2011, 09:49:02 pm
So I'm installing the new guides, for some reason the guide that was worn is also oversize so I'm talking with air cooled engines plus to see what we can do about that.
In the meantime I installed the rest and am in the process of reaming 'em to fit the valves.
The bentley says "with the valve keeper end flush with the guide and using a dial indicator on the edge of the valve head, the maximum slop permissible is .051". (not word for word 8))
When setting new guides and valves what should it be using the bentley method?
The guy at air cooled engines plus said that if I can feel any slop with my fingers then it's good, but I'm not sure if that's at full lift, bentley method or just off the seat.
