General Information => Upgrades (non engine related ) => Topic started by: GEE-BEE on January 28, 2011, 05:37:17 pm
After cleaning out the a/c assy and duct's , I also added all new silicone foam on the vent door's
installing new blower fan assy and heater core assy ( 200.00 parts )
red silicone hose from heater to firewall
The shop did not have to use the jetta dash bracket's
Trevor ( member )did a fine job on the cluster and installed the blue LED's and white meister gauge faces
All functions work !!!
The fan blower is much stronger and there is no rattles in this dash assy now that there dymat insulation and silicone foam on all attaching surfaces
Next will be a new Blaupunkt Stereo with DVD /CD function with pop up dvd screen to finish
Gee-Bee
Gee Bee I would love to see some pics. I'm gonna do this to my caddy this summer so any tips or tricks you may have would be nice too. You can send them to john at bigrblasting dot com Thanks
same foam you sent me? Do you have pics of how it went on. I think I put too much on mine, but can't pull the dash until summer time to find out. I still have little flow.
I will send some pic's, I had a shop do the install while I went to japan and two islands in the Philipines
Boracay and Palawan
Water was warm 78 and air temp was around 87
Great food and diving
For questions please contct Brad at Mesa West ( Costa Mesa Calif.)
His email is :[email protected]
( Ref: Dash Install )
The wiring was a problem as my truck was a gas and I had two get a MK1 diesel jetta cluster and add a tach, all functions work perfect now in the cluster.
If i did it again , I would do a diesel harness swap
You mean if you had someone else do it again. ;)
I was just saying that a diesel harness would have been much easier to deal with, I had to install a Bosch universal glow plug kit also and delete alot of wiring for this install.
gas to diesel
GB
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/DASH0012.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/DASH001.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/DASH002.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/DASH003.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/DASH004.jpg)
I spent some time cleaning, Nice work on the cluster Trev !
Installing new newton carpet kit in a few weeks...
Will be installing new CD/DVD stereo in the next few days
GB
thanks, no timing advance?
What ?
Timing advance lever
not installed
Start's first turn with Bosch fast glow plug's and fast relay
GB
GEE-BEE, if you don't mind, what did you pay in shipping for the carpet kit and who did you use for shipping?
There carpet kits and peices of kits are by far the best fitting and the colors match OEM carpets.
I havent heard, why do you one ?
they havent advised yet
we could ship two cheaper than one ?
I'm interested in the Scirocco rear parcel shelf carpet set, Biscuit color. I think they want $80 just for that. The last I time I contacted them via email, they make every order to order, so it would be a while. They also would'nt tell me who they use for shipping. Don't know why.
Aaron at Bleached Bora can get great shipping rates, but they won't use anyone but who they choose.
Let me know.
Thanks, Josh
GEE-BEE, What are your door panels from ?
They were special order TMI for a Cabby, 3 hole door handle type with mirror hole
I added the early bug chrome door surround
cabby door pull's
cabby speaker grill's with Fogul speakers ( 300.00 )
Window crank's from rabbitparts.com
Nice fit & finish..
I found a new Blapunkt Chicago stereo with FM/CD/DVD with pop up screen , retails for 1100.00 new in the box for 200.00
Wow. If you ever need parasite friend I will volenteer. That is some awesome looking stuff that I will never afford. :D
That really looks great GB !
Where did you find such a nice dash ? lol
The whole interior is dynamite !
The scrabbage/ruffle under the glovebox (in close up photo) wasn't like that when it went into the box. Might just need an altering adjustment there. idunno
So the Rabbit dash support brackets were a strait fit ?
I noticed you stated they didn't need to use the Jetta brackets.
That would be a good thing to know for future refs.
Also for future refs - almost EVERY (maybe ALL) connectors/plug-ins are different from rabbit-vs.-jetta. You'll definitely want the entire fusebox and wiring harness from jetta if you plan this swap.
And ... rabbit cluster won't work in jetta dash either.
Basically, you'll need EVERYTHING from donor car.
Including ductwork etc...
GB got Everything EXCEPT wiring harness from me.
Figured he had other plans for that area.
I have another MK1 Jetta with complete nice (black) dash conversion (a/c). Missing driver side lower dash plastic pocket tho.
Factory diesel - all wiring intact - including engine harness too.
However much someone needs - its all there.
Also the 5spd console too.
Just mentioning in case anyone else has the itch to switch.
Correct, just modified the stock dash bracket's
dash is very quiet, it's clean now with a elbow grease
Thanx again Baron !
Trevor did the cluster for me with a Meister gauge decal and tach, so just the shop had to splice the gas harnedd to the diesel cluster harness
didnt install the a/c condenser, and the center vents work perfect
I did install: new blower fan,heater core,new side vents from MK1Autohaus
Truck is going to stereo shop and install 16V antenna and CD/DVD Blaupunkt Stereo with pop up screen
Iam still waiting on my Odyssey dual horizontial battery mount for under the bed
GB
