Engine Specific Info and Questions => IDI Engine => Topic started by: g-spec on January 07, 2006, 08:55:21 pm
Title: Camshaft ???'s
Post by: g-spec on January 07, 2006, 08:55:21 pm
i am in need of a new camshaft for my 1.9 TD!!! mine broke!!!
which ones can i or cant i use!!!!
thanks
Post by: dieselweasel on January 07, 2006, 09:04:11 pm
Where did it break and why?  Your best bet is to get a used cam for the same engine.
Post by: g-spec on January 09, 2006, 08:10:58 pm
well i found a camshaft for $50 can.....its in better shape then the one i had b4 it broke!!!! car runs after a full rebuild with a nice crack fix done by "quickTD" (thanks, i wont be bothering you anymore haha)
thanks for all the help!!!
ill be posting here soon again about upgrades......i alreayd searched a lot!!!
cheers
Post by: g-spec on January 12, 2006, 10:00:52 pm
just wanted to know if there is a major reason why a timing belt could/would break???
thanks
Post by: 935racer on January 12, 2006, 10:55:38 pm
Quote from: "g-spec"
:shock:
QuickTD hook a brother up 8)
Just kidding of course.
Post by: QuickTD on January 13, 2006, 06:27:05 am
thanks
Old or defective belt, excessive belt tension, seized injection pump or camshaft, siezed intermediate shaft or accessories driven by the intermediate shaft (vacuum and oil pumps), foreign object under the belt. The list goes on. Please don't tell me yours broke, you're luck has not been good with this car...
Sorry, as lucrative as the crack business might be, I don't have the sort of luck necessary to succeed at it... :D
Post by: g-spec on January 13, 2006, 09:42:20 am
Yes mine broke!!!!! the car was running nice and even ideling i was waiting for the fan to turn on so that i could top up the coolant and snap...motor stopped!!!!!!! new timing, new head gasket, new bolts and i have some good valves still that im going to use to replace the bent ones with!!!!!!!
if one more thing happens to it....im getting insurance and setting it on fire!!!!!!!!
Post by: jtanguay on January 14, 2006, 04:33:24 pm
you would get quite a bit for it mind you... my 1986 1.6TD Jetta GL (no accessory options like PS or A/C manual everything)  was appraised at $2260 canadian.   Car had over 270'000 km!!!!  Diesel has a nice resale value :)
Post by: g-spec on January 19, 2006, 08:55:52 pm
ok so...after all the bloody knuckles and bad words...it finally runs....after a full rebuild...then cam broke...then once running the timming belt snapped....so i pulled the head pulled all the valves to check if any are bent....and replaced 3 cracked lifters.....valves were ok...suprisingly....and car finally runs like a champ....took it out for a spin....nothing long...it needs a sticker for the plate and insurance....but it finally runs!!!!
thanks
Michal
Post by: QuickTD on January 20, 2006, 05:55:00 am
Everyone think good thoughts about g-specs car, he's not been a lucky man so far...
Post by: g-spec on January 23, 2006, 06:42:27 pm
so....car is running well.....doesnt smoke...idles awesome....starts no problems......im happy...and overall i think all the problems worked themselves out!!!!! now i have a question.....
i made about 1000km...and i tuned the pump....i wanted to know how much smoke is too much????
Post by: TDIMeister on January 26, 2006, 11:14:57 am
All depends on you; your threshold and how much you care that others are scorning the trail of smoke you might leave behind your car...
For your repair needs, also look up Gerry in Dorchester.  Great guy and he knows VW Diesels as well as anyone in the area.  gdewit at sympatico dot ca
