Engine Specific Info and Questions => IDI Engine => Topic started by: gribur on January 07, 2011, 10:51:03 pm
I have an MK3 golf AAZ i need a used cooling fan assembly and Was wondering what the difference is between the rad cooling fans on a car with a/c and one without a/c. Can you use either one? Is $50 a good price for one used?
Cheers guys
non a/c - Auto trans fan is 450/250 watt two speed
1H0959455AD
man trans with or without air
a/c model is 250 watt single speed
1HM959455C
both models use a 305 mm dia fan
There is a belt that drives the aux 1H0119137
GB
I would find any fan & shroud no lower than, as GEE-BEE stated, 250 watts. watts (over size) are a good unit of measure for the kind of air flow the fan can produce. Unless it was designed by people who shouldn't be making fans and is remarkably inefficient for what ever reason.
A little bit of a pain to do but a Ford Taurus fan and motor is the poor mans flex a lite.
