For Sale/Looking For => Parts for Sale/Wanted => Topic started by: jasonsansfleece on January 07, 2011, 10:06:49 am
Title: WTB Flywheel, Pressure plate
Post by: jasonsansfleece on January 07, 2011, 10:06:49 am
I'm wanting to upgrade the clutch on my 1.6td.
So I'm looking for a flywheel that will take a 16v pressure plate and has small splines for a 020 transmission.
I think I have that right,
Title: Re: WTB Flywheel, Pressure plate
Post by: R.O.R-2.0 on January 07, 2011, 12:25:42 pm
you need a 16v pressure plate.
and an 8v clutch disk.
and a 9 bolt flywheel.. gasser flywheels are lighter than diesels. but i wouldnt go with a lighter than stock flywheel unless you turn more rpms than the factory governor allows..
the 6 bolt diesel flywheel wont work with the 16v pressure plate.
Post by: rodpaslow on January 07, 2011, 12:52:59 pm
Yup, watch how many dowels the flywheel has as some later ones have two and may not fit the 16V pressure plate.  The dowels I think are removable, but not sure if one is removed it the TDC mark is in the right spot.  Also-if and older gasser flywheel(one dowel)- before you mount it mark a TDC mark (I think about 5/8" from 6° timing mark) for properly timing the diesel.
Post by: jasonsansfleece on January 07, 2011, 05:50:42 pm
Thanks guys,
I now understand!
Whilst we are at it...
Are all pressure plates/ discs created equal?
Techtonics (Sachs) and ACT both sell suitable PP/ disc combinations. The yellow paint and price suggest the ACT is the better  ::)
I would guess the Sachs is OEM and the 16v put out what, 140hp?
Opinions?
Post by: ilikevwdiesel on January 07, 2011, 06:02:34 pm
I have a flywheel and pressure plate for you but no disc.
Post by: jasonsansfleece on January 08, 2011, 05:24:11 pm
PM sent
