General Information => Upgrades (non engine related ) => Topic started by: GEE-BEE on December 08, 2010, 03:27:39 pm
After looking for more room in the engine compart area I decided to do it another way !
Odyssey Battery for under the bed
Model ER40 : 9.8 Long x 3.8 Wide x 8.1 tall
Weight 27.5
1100 cca
I will be using there HDER40 battery mount and send it to a shop that will make a horizontial side load battery tray.
I will place it forward of the tire carrier, and plan on welding on a 316 s/s 12 X 12 X 3/16 thick plate for the support the battery tray.
found this shop :
http://www.speedpartz.com/foz_batterybox.htm
I will use a 2/0 cable from the battery to the remote terminal ( BMW E30 Model )
GB
I'm intrigued! What happened to the behind the seat idea? I think I'm still planning to go behind the passenger side seat with my redtop, if it will fit in a box?
I have corrado seat's , no room back behind mine...
I going with a horizontal mount just in front of the spare tire carrier..
ground off probly a 1/2 lb of undercoat to have a clean weld for the plate
GB
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/CADDYTAIL001.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/CADDYTAIL002.jpg)
couldn't resist
(http://img.photobucket.com/albums/v306/Trev0rbr/YEHBABY.jpg)
Note :Iam going with Speedpartz to make a piggyback model to hold two ER40 odyssey battery's
I sent him a vertical ER40 battery mount to copy...
GB
What are you using for rear bumpers???
Those are the South African Bumperette's
I switch back and forth when I need a to tow my zodiac or jetski trailer
