Engine Specific Info and Questions => IDI Engine => Topic started by: wiener on November 26, 2010, 07:11:08 pm
Title: boost drops off unexpectedly
Post by: wiener on November 26, 2010, 07:11:08 pm
Did some minor mods on my pump(fuel screw etc),disabled the governor added a fresh air intake,have pyrometer   and boost gauge.
the boost occasionally will hit 25lbs.(but often only 15 lbs.boost) and usually drops back to 10 lbs.
I have played with the waste gate and even disabled it with no positive results.
Do I need a bigger turbo? Am running a stock turbo on my 94 AAZ Jetta and planning to upgrade any suggestions as to replacement turbos? FMIC coming soon also.
Title: Re: boost drops off unexpectedly
Post by: hairyuk on November 26, 2010, 10:04:07 pm
could be your wastegate
Post by: wiener on November 27, 2010, 08:26:37 am
 played with and disabled  wastegate and it didn't help
Post by: RabbitJockey on November 27, 2010, 10:04:09 am
which turbo do you have?  kkk turbos are alot of sticky wastegate valve issues, could also be an exhaust manifold or intake leak
