General Information => Upgrades (non engine related ) => Topic started by: GEE-BEE on October 25, 2010, 05:33:48 pm
Got a 16 v harness, made a another relay fuse to battery
Installed new MKII 16v a/c fan 250 watt vesus 150 watt
6 blades versus 4 blades
It turned on at 200 and it was so quiet now I didnt tell it was on, it's has much more pulling power, was on for a few seconds before turning off
Great Mod, I did the MKII fan support also, Better fitment than the MKI upper U clip on the fan support to core support...
Iam not running a/c, the switch is a 85/92 temp
I belive it's turning on at the higher temp rather than the lower ( wiring ) I think the other high speed function of this fan only turns on with the a/c realy installed on during when the a/c compressor is installed ?
GB
this must be the one that just has one motor and fan? thats the big bulky unit.. the dual fan unit would have been a better upgrade..
they move SOOO MUCH MORE AIR than one fan could think of moving..
Dual is a different radiator fan support
I went from 575 mm to 675 mm on the radiator , the new 2' deep intercooler that iam having made custom will fit on the 675 mm front tab's
easy peasey
GB
did you get a 16v rocco rad fan? or a mk2 16v rad fan? the mk2 16v fan and mk3 fan are ALMOST interchangeable. just cut ~1" off the bottom..
the fan in my 16v car, and the fan in my 8v GTI are almost identical, just a different plug on the fan motor.. had to swap the plug on my GTI wiring for one off a CE2 car (90-98 fan pigtail)
I got a new scirocco16 v a/c fan and used fan support , powder coated satin
16 v wiring harnees with a 20 amp relay wired into the battery
perfect, waiting on my cutom 1-1/2 thick intercooler made for the 675 mm radiator ( bolt on )
cool, but i still would have used the thin dual fans.. they look ALOT cleaner to me atleast.. and your truck is a pretty clean ride G.B..
I Found a 1996 jetta 1.9 fan support dual ) for 25.00
New fan is 41.50 ( three pin ) and I will buy a new aux fan and belt from AZautohaus if it fit's the 675 mm Radiator ,the stock MKIII is 628 mm
This will allow with the thinner blade I can move it a tad to the right for more IC tube roo
Moving the battery ( optima 1000 cca ) with a cnc mount 90 degrees gave more room for the side intercooler tube
Waiting on my Bedrug for the bed and a custom Jetta cluster in white for my jetta dash swap in two week's.
I will be able to throw my yamaha superjet in the back of the caddy and start wave jumping again here in Orange County
Was 80 degree's at the beach yesterday
GB
MKIII DUAL IS RADIATOR IS 628 X 377
FAN SHROUD IS 15 X 27
MKII IS 675 MM
SHROUD 13 X 28
Tab's wont mount
MKIII is to tall for a MKI core support
GB
Looks like aftermarket dual is the only way....
i just made up mounting tab extensions..
Is it a tight fit around the shroud to radiator ?
send me a pic to [email protected]
What model shroud did you use ?
I want to cover the whole radiator for maxium cooling
Flex a lite has various option's
New oem jetta dual fan's are around 200.00 pair
GB
GB
used mk3 Jetta slim dual fans.. they are too tall for a mk2 rad as they come stock tho. so you have to shorten it a bit. and i just used some chunks of scrap aluminum for my mounting tabs..
I want complete coverage, So I will send the extra 675 mm radiator to Flex A lite, I hope to get a 2-5/8 thickness with no gap's
There model 340 looks nice
I want to use the mounting tab's on the tank as bellinterooler is doing on the opposite side
GB
i dont even care about complete coverage.. the original fan never let my car get hot. so im really not worried with 2 fans..
the stock fan doesnt even completely cover the radiator..
Again, it's not about your Installation..
I'am showing another option
Since the custom bell intercooler will cover this radiator ( front) and partial intercoolers are not as efficent as complete coverages ( oem VW )
Complete coverage of a fan shroud will draw more air and it will mount to the tank tab's and have a seal around the fan shroud for efficent seal.
I make intercooler seal's for Cessna Aircraft ( 550 CU ) twin turbo charged, 25 new aircraft per month
So I do know how to properly seal a Intercooler...
I have been mfg aircraft seals and duct's for over twenty years now...
Google:Gee-Bee
You do it your way ,I will do it mine....
I have the resources to do it correctley
GB
i wasnt saying anything bad about anything, just so you know.. or about your build..
just that it doesnt matter to me that it isnt PERFECTLY sealed. its a VW, not a Cessna.. thats how i think about it.
and being me, i never drop over $1000 on whole cars.. and being you, you regularly drop over that much on a couple parts!
now thats devotion.. atleast your spending your money on a BAD ASS caddy, rather than a civic! lol.
Thanx, going to a 1990 dual passat 1.8 fan assy
I moved the radiator far left
this fan uses a drive belt and mounts to the 675 mm 16 v fan
GB
Update
1990 Passat dual fan will bolt on the 675 mm radiator, It has a belt driving the aux fan
26-1/2 wide x 13 ' tall
I found four new all brass NOS radiators ( behr) Three a/c type and one non a/c type
A/c model's have angle top outlet to clear the alt on 1.6 a/c applications, there also used on the 16 v scirocco 16 v setup
GB
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN001.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN002.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN003.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN004.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN005.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN006.jpg)
(http://img.photobucket.com/albums/v306/Trev0rbr/geebee/PASSATFAN007.jpg)
And yes it fits the MK1 with the 675 mm scirocco 16 v radiator
GB
As "neat" as that belt driven aux fan is, my first thought is great, something else to fail.. :)
All new parts installed: fan's and belt
perfect fitment, runs for about 7 seconds after it reaches the 205 mark
GB
what about changing the drives over to something like a Gates power belt set up. you could get better rpm with a smaller hub. just thinking about making the drive set up more reliable. I bet you can get another 30 or 40 cfm extra and no real slippage.
Do you have any pics of this radiator and fan installed? I would like to see the clearances on each side. Sounds like a great option.
emlail me at [email protected]
