Engine Specific Info and Questions => IDI Engine => Topic started by: towns on December 29, 2005, 11:52:35 am
I just finished installing 2 of the 4 pistons back into the engine after replacing the rings (1.6 TD), and as I was turning the crank, it seemed much stiffer (harder) to turn than when I had been turning it with the original rings. Is this stiffness typical after a ring replacement?
It's typical for an engine to be tighter with new parts installed. That is why when you buy a new tdi it will get progressively better mileage through break-in.
i should also mention that i installed new connecting rod bearings
I found one possible reason for the tightness in the crank. Following the Bentley's instructions on piston installation can be slightly confusing, it turns out i installed the upper piston rod bearing (on piston side) the opposite way and not in the groove... :oops: Good thing i caught it before i went any further. This must have played a role in the extremely stiff crank.
Yeah, that would've been bad. I'm not sure you want to use that bearing anymore though.
