Engine Specific Info and Questions => IDI Engine => Topic started by: polo_td on August 31, 2010, 01:05:30 pm
As topic.
I found several topics about how to do a gov,Mod on the Golf pump but nothing on this type of pump.
So, if there is any one ho has done this or can figure this out i rely appriciate it.
here´s the pump numbers.
OE .- Del nummer: 031 130 107b
BOSCH numret: 0460484036
Thomas
Sweden
do you have any pics?
Just this one at the moment.
(http://forumbilder.se/images/51201070745AM56a2.jpg) (http://forumbilder.se)
(http://forumbilder.se/images/032009105136P5339.jpg) (http://forumbilder.se)
Thomas
if you have it off of the car almost everything should be the same, from what I can see the biggest difference is that you only have you spring instead of three, which should make dis-assembly, and assembly easier. other than that it doesn't look really different, and once you get inside the governor should be the same as on all the rest of the pumps, but I don't know that for sure. hope that was helpful.
Ok, Thanx for the reply.
Thomas
One option would be to pull the lid and take a picture or two... the smart folks here will likely be able to help. As previously posted, there's an excellent chance you're going to find the exact same governer setup as detailed in the HOW-TO in the FAQ section.
