Engine Specific Info and Questions => IDI Engine => Topic started by: 89VWdieselGolf on December 23, 2005, 04:40:44 am
Title: 400Km's alot for our cars?
Post by: 89VWdieselGolf on December 23, 2005, 04:40:44 am
Hey,
As most of you know (if you browse the for sale section) i'm looking for another diesel again...desprately,
I found a 92 2 door golf, but it has 393Km's on it.
I know vw diesels can go for a while but is that past it's limit?
And how do the body/chassis hold up after 400Km's?
thanks,
Jeff
Post by: jtanguay on December 23, 2005, 10:21:25 am
I bought a '92 jetta 1.6TD with 372'000k on it.   The valves seem to make a lot of noise so I'm guessing I need a head rebuild soon.  It starts alright in winter with the cold start, but bucks without it (which is normal).
The exhaust bowl gasket is gone, as there is exhaust that comes out of the front grill on my car (not good...).  I had to replace a motor mount, AND the rad fan (which ruined my air conditioning system btw) and soon I will need to replace my heater blower :(.   The car doesn't seem to have as much power as my old one did when the boost comes on, and does seem to have crappy mileage (winter is now around 600km/tank and summer was 700km/tank).   I just purchased a new suspension consisting of struts and shocks, strut bars upper and lower, and stiffer springs which will help make the ride feel not so 'bouncy'.
Those are the main problems I can think of, unless there is damage to your turbo (which is one thing on my car that spools perfectly when warm)
oh and tires.   If the PO didn't put new tires on, change those too and/or get an alignment done which helps!
Post by: 89VWdieselGolf on December 23, 2005, 10:25:03 am
ewww that doesnt sound like a good list
thanks,
Jeff
Post by: vwmike on December 23, 2005, 10:28:51 am
Well, my Jetta has just over 360k km on it so I guess it's close enough to have a say. The body isn't too bad but I had to replace everything in the suspension and braking system. The ball joints were worn out, the tierods were worn out. Shocks and struts were shot. Steering rack was broken. The master cylinder was bad and the softlines were done. It all made for a terrible driving experience. After I replaced it all and did the maintenance items on the engine as well as a new clutch, wheels, tires, etc it was good again. If these things haven't been kept up with, the car isn't cheap, and you don't plan to do the work yourself then it's probably not a good investment. Another thing to keep in mind is the engine. Someone has replaced the cylinder head once upon a time. I had the head off to swap on an AAZ gasket about a week ago and i can tell you the cylinders definitely aren't straight anymore. They're not wavy, but over time they become more cone shaped with the bottom being larger so if it is to be rebuilt it will require new pistons. It still starts fine when it's cold out (relative - cold means freezing temperature).
Post by: MacGyver on December 23, 2005, 10:45:50 am
Generally VW diesels are capable of significantly more than that, but with that age of car, it's something now best evaluated on a case by case basis.
My first diesel, 87 Jetta, engine was very tired @370k km. I bought it with 170k km. Body/chassis was still decent till the end. I sold it to a guy I think used it for parts.
My dad's had a couple MKII's exceed 600k km.
I fully expect my current 97 to go much further due to my more knowledgeable care & maintenance (ie synthetic oil etc), and the fact I got it with 54k km so I know what it's received for treatment & care for most of its life.
Talk to QuickTD in a few yrs, he's >260k km now...I expect his car will last forever :D
Post by: 89VWdieselGolf on December 23, 2005, 11:24:20 am
this car i was looking at is a car at a dealer for 1G, trade-in special, i don't think i'll be taking my chances with it, although the motor apparently runs great, who knows about suspension, brakes etc.
thanks for your help,
Jeff
Post by: jtanguay on December 23, 2005, 11:31:50 am
Quote from: "89VWdieselGolf"
Jeff
ask to go for a test drive, and drive over some pot holes with it.   Its pretty easy to tell whether or not the suspension is gone (mount, shock, spring)  when you go over a bump.   A bad spring can make sort of a  clunking noise.  Bad strut/shock and the car will feel pretty bouncy.  Replacing ball joints are almost mandatory as the wheel will fall off if they are bad :(  if you are buying it from a dealership though, they should have to fix that if its bad when they do the safety inspection.
1g for a '92 diesel is pretty good actually.  I spent $2800 for mine and feel I got a little bit ripped, but the body has no rust whatsoever and brake lines are pristine which makes it worth it.   Even if you have to spend around 1500 on repairs for this car (never take it to any garage) then it is definitely worth it.  Cheap insurance and cheap on fuel if driven properly.
Post by: 89VWdieselGolf on December 23, 2005, 11:37:44 am
Quote from: "jtanguay"
Well if it wasn't shot before the test drive it sure is now :P  j/k
thats a good idea though
thanks,
Jeff
Post by: detour1999 on December 23, 2005, 12:43:32 pm
Quote from: "MacGyver"
Couldn't agree more...
my daily NA has about 420K km on it.  The body is close to perfect (NO rust...  which is odd for Chicago).  Engine is in fine condition (some difficulty starting under 20F) I redid all the brakes and suspension, since I had them lying around.  Been driving it for over a year and have loved every second of it.
the ecoDiesel I picked up, on the other hand had about 230K km when I got it.  Brakes, suspension, body, transmission and clutch were all shot.  Engine purrs like a kitten, though. (Well, a loud kitten ;) )
Suspension, brakes, etc are all pretty easy to replace yourself.  If the body and engine seem to be good, I'd go for it.
-d.
Post by: zyewdall on December 24, 2005, 08:36:04 am
Like a few people have said, it's a case by case evaluation of whether it's worth it.  But $1,000 sounds like a pretty good deal for any running diesel, considering it's a turbo too.  Around here, old 1.6NA rabbits are selling for over $1k if they run and the seller knows what the market is like.  Older TDI's are selling at 50% or more over blue book.
Post by: Op-Ivy on December 24, 2005, 06:50:49 pm
I just hit 430k last weekend :)
Ill get a picture when I get hold of a camera!
Post by: vwmike on December 25, 2005, 12:36:28 am
Quote from: "Op-Ivy"
That's a lot of miles.... so take warning.
(I think I should reply to all of your posts with an Operation Ivy reference).
Post by: Op-Ivy on December 25, 2005, 10:42:11 am
Quote from: "vwmike"
Caution is a word that I can't understand :)
Post by: mortskeg on December 25, 2005, 03:54:21 pm
My 81 pickup has just over 310,000 miles on it (about 500,000km?).  I went though last year and replaced the ball joints, a-arm bushings, strut bearings and bushing insert thing; some of these parts were original.  Needless to say it is not the original engine, but the rest of the truck has held up to the miles very well.  IIRC it had a bit over 400,000km on it when I bought it nearly 7 years ago.  So personally, I wouldn't shy away from a vehicle with high milage, provided that the maintenance has been properly kept up with.
Hope this helps.
Post by: 1985JettaTD on December 25, 2005, 10:54:22 pm
my 1985 Jetta with a 1.6TD just hit 510 000 last weekend. only major work has been headgasket, alternator, waterpump, mastercylander, and rear shocks. it still has the vw original muffler and transmission. it still drives great with lots of power and getting great milage (about 1300km a tank) i am in love with the car and would never buy anything eles. go for it they are not that hard to fix if anything goes wrong and they last forever and not to mention how hard you car drive them and it loves it.
Post by: jtanguay on December 26, 2005, 01:42:13 am
oh yea i forgot to mention.  ask when the transmission fluid was changed.  if no proof can be shown to you that it has been done, do it!  I changed mine maybe 3000km ago and it was dirty as hell.   After that it shifted better and was much looser.  I got it rust checked and the shift linkage was lubricated to make it shift even easier in winter time, not to mention steering seemed more fluid-like from the lube.
only problem with my tranny now is that when i shift in 2nd i have to wait for the rpm's to drop, otherwise it grinds (but still goes into gear) which doesnt sound healthy, and sucks when i'm trying to accel hard.   other than that the tranny is great!
Post by: Laurentian on December 27, 2005, 03:05:59 pm
My '91 1.6D Jetta is at 400,000+ km's with near perfect body.
I rustproof it myself like crazy and had the windsheild perimeter repainted
following a leak. I user Superlube spray or grease on all the electrical contacts / fuse box and teflon grease on doorlocks  and doorhinges, etc. As for the floor pans I welded a few minor holes and reapplied / dried undercoating inside. Watch out for water leaks!
My next big job is to redo the undercoating underneath.
I will be taking my sweet time rebuilding the 1.9TD motor I picked up.
The 1.6D can run to 800,000 km's with basic maintenance and Mobil 1 or equivalent oil / filter changes.
I would like to have the injectors rebuild buit am afraid of cracking the head upon removal.
Of course mostly everything has been replaced over the years but have not had the head off yet.
I want to keep the car another 10 years.
I am not even the least bit interseted in the newer models.
Hugh
Post by: tylernt on December 27, 2005, 04:45:41 pm
Just a worn out 2nd gear synchro. I used to think it was just me but apparently it's somewhat common. If you can shift without grinding, you can drive it like that for a long time.
Quote from: "Laurentian"
I have the head off my NA 1.6... no cylinder ridge that I can detect with my finger or fingernail. At 142,000 miles I guess it's just a young'un. :)
Post by: NOTORIOUS VR on December 28, 2005, 05:57:40 am
I got around 413 000 on mine... and after some TLC she runs GREAT!
Of course there is some blow by, but hey you can't have it all  :D
Title: Re: 400Km's alot for our cars?
Post by: chrissev on December 29, 2005, 04:24:33 pm
Hey,
thanks,
Jeff
my jetta TD did 350,000 before needing a rebuild.  But it had like 8 owners and they drove the crap out of it.  The "used vehicle information package" is like 4 pages long.  Everyone who owned it eventually sold it back to the dealer that originally sold it new, and it was resold.  I am the first person who didn't buy it from the dealer (got it with an "as is" title from a guy in Georgetown, who bought it from the dealer)....but anyway, the service life of the engine seems to depend to a large degree on the care that is taken of it and how it is driven.
Post by: bhtooefr on December 30, 2005, 04:09:15 pm
My Jetta has an estimated 275,000 miles (that's 440,000 km). I paid $1200 for it. The body's in good shape, just a little rust, and the engine seems to run fine.
FWIW, $1200 would normally buy me a rusted out Rabbit in imminent need of an engine rebuild, around here... :roll: The guy kinda knew the market, but didn't REALLY know what he had. I felt a little guilty paying $1200, even though it was slightly over what I wanted to pay...
Post by: Malacaco on January 07, 2006, 12:47:44 pm
I changed my 1.6d engine after 521.000 km, and it was still running, but the compression was getting a little low, now have a 1.6 td with 160.000 km. The chassis is still in good working condition, so the suspension arms, steering, electrics, etc
