General Information => General => Topic started by: srgtlord on August 17, 2010, 05:38:10 am
Title: Crazy idea? 1992 3 speed automatic transmission with 1.6 diesel engine?
Post by: srgtlord on August 17, 2010, 05:38:10 am
Was just wondering if this would work at all and if I would need any special parts to complete the swap. FYI this would be going into a rust free 1992 vw cabriolet.
Title: Re: Crazy idea? 1992 3 speed automatic transmission with 1.6 diesel engine?
Post by: honda_is_the_best on August 17, 2010, 08:02:41 am
need one key piece.. an ever so illusive auto diesel starter.. made from unobtanium..
and all the mounts/brackets/cables/shifters that pertain to the installation. ive thought about this swap before, it would be fun in a car with a turbo, and some power, because you could spool the turbo against the transmission.
Post by: 8v-of-fury on August 18, 2010, 07:24:37 pm
a 3spd auto trans is spinning 3100 at 65mph.. Bad Bad diesel ratios.
"096" 4 Speed Automatic code CFF from a VR6 Corrado, Golf/Jetta III, Passat. It will spin 2400 at 65mph, dunno if it would ever work.. but a 4spd auto would be way better Idea..
Post by: maxfax on August 18, 2010, 07:27:33 pm
The 4 speed is electronic but uses a stand alone controler IIRC..  Not sure what inputs it would need..  TIme to have a look at alldata......
