Engine Specific Info and Questions => IDI Engine => Topic started by: jpedro on July 05, 2010, 09:42:05 am
So im replacing rings in my 1990 1.6ltd where is a good place to get stock replacement rings? Im going to pull the pistons out today but when i do so is there anything special i need to do in accordance with removing the oil pump and upon reinstalation is there anything special i need to do to it?
I got mine from Autohausaz.com. I bought the Grant Rings, but you can buy the Goetze ones also. My Grant rings were right at the minimum opening when pre-installing in the cylinder bores. I had to open a few up to get to the minimum, no big deal. When I installed my oil pump, I just made sure that the keyed drive lined up with my rotary vacuum pump. Also, there is a small o-ring type gasket that fits between the oil pump and vacuum pump on the keyed shaft. I replaced mine while I had it out. Some people don't replace it, but I have heard that the o-ring type gasket creates a better seal for the oil pump.
K cool and as far as stock sized piston they are 76.48mm am i right im not sure if this motor has ever been done how can i identify this?
take and mic the bores. at the top, middle, and bottom of the pistons travel. that will tell you what pistons you need.
Also, once you pull the head off, they will be marked with their size on the top surface (under the carbon).
Hey I'm in BC too. If you haven't already got the rings i may have a full set of grant's at my parents house i could sell to you for less.
PM me if you're interested.
(i can't garentee that i have a full set though. I bought 4 sets and i sold one but i remember braking an oil ring. Between the two boxes i still have i definitely have a full set. However, 1 box was the three piece oil ring and the other box was the 2 piece oil ring style. Both styles work just fine. Let me know if you want to save a couple bucks - i need to sell them as i dont have a 1.6 anymore and im super short on change so i'd easily go halfers)
sorry smokey eddy, i would have grabed them off ya if i knew 2 days ago, i just got a set of grants from napa for 92.99. i just sent my head down to kelowna to get milled because it was warpped a bit should have that back late next week and my rings cam in today, also have a new head gasket so im almost ready to make er run again, kind interested to see what its like once shes all done.
