Engine Specific Info and Questions => IDI Engine => Topic started by: Golf/Jetta on June 18, 2010, 10:20:04 am
Title: 1.9L Turbo off - eninge misfire's at higher RPMS
Post by: Golf/Jetta on June 18, 2010, 10:20:04 am
1.9L TD, 97 Jetta
complete head rebuilt last year
no leaks nor oil missing/coolent
new injector's this year
glow plugs changed two years ago.
timing on the button
compression 390 - 410 PSI
no blue, white, black smoke
running with the turbo its fine @ higher RPMS but when the turbo's waste gate is opened (off) the engine misses at high RPMS..
i had the air box off during the winter months (conned filter) didn't misfire with this
then put it back on during the summer (K&N filter) and it misfires
what gives?
thought?
Title: Re: 1.9L Turbo off - eninge misfire's at higher RPMS
Post by: Rabbit on Roids on June 18, 2010, 11:26:20 am
i think its probably a miss firing injector. my audi does the same thing above like 4000. real loud popping and it smokes..
Post by: dankcorey22 on June 18, 2010, 01:22:35 pm
It may be the fuel. you dont have enough fuel going to the pump at those RPM's. To solve: Get a lift pump
Post by: the caveman on June 18, 2010, 03:52:03 pm
A lift pump is a band-aid. It's not really solving the problem.
Post by: Aki-76 on June 18, 2010, 09:55:05 pm
i think itīs lda.when waste gate opened,boost go sini wave and lda get inaccurate feed.
Post by: Rabbit on Roids on June 19, 2010, 10:22:59 am
wow, this thread drew a response from Aki, thats surprising.  ;)
Post by: Aki-76 on June 19, 2010, 10:22:16 pm
Post by: the caveman on June 20, 2010, 02:36:48 pm
Do you have a lot of bubbles at the fuel line. If so, replace your fuel filter and check all the fuel line connections.
Or as Aki-76 said, the LDA is not working or is not getting it's vacuum signal from the intake manifold. Is the small hose bad/disconnected/missing/collapsing from vacuum?
