Engine Specific Info and Questions => IDI Engine => Topic started by: Sampson on June 09, 2010, 07:39:41 am
Title: Governer Mod HELP!! Did I mess something up!?
Post by: Sampson on June 09, 2010, 07:39:41 am
I performed my Governer mod las tnight - Spacing only the main spring by 4mm.
Now. It wouldn't start at first - I had to up the fuel and raise the idle to get it to start and stay running. (800rpm)
I then test drove - No smoke, Less power, A lot less boost. (before I modded i had smoke, lotsof smoke)
So I upped the fuel to the point where it would idle at 1000rpm. It was a little better - a bit more smoke and a bit more power. But still no where near what I expected. I feel that it was faster before.
NOW
I was jsut out on my lunch and it tried to run away in first gear. Too much fuel is my first suspicion but I have no smoke, no power and like 6 psi less boost. I am faily knoledgeable on these engines - But I am at a loss. I double check i got everything back on as it was prior to the mod.
Anyone have any ideas?
I am going to take it back apart tonight to ensure I have everything hooked up properly inside the pump.
Title: Re: Governer Mod HELP!! Did I mess something up!?
Post by: RabbitJockey on June 09, 2010, 08:38:23 am
did you maybe put your throttle on in the wrong position
Post by: Rabbit on Roids on June 09, 2010, 10:07:44 am
thats my bet. missed by a spline or 2..
Post by: Sampson on June 10, 2010, 03:16:46 am
And this is why I love this place!
After a closer inspection and cleaning all the paint off my throttle plate - It was most definitely off one tooth. Set it up again and the car is now a beast!
Thanks again!
Post by: RabbitJockey on June 10, 2010, 01:57:30 pm
awesome we now deserve a movie
Post by: catlin_cava on June 11, 2010, 08:30:03 am
Yup, I must see what this car looks like in motion, it looked pretty sweet at MVOC ;)
