Engine Specific Info and Questions => IDI Engine => Topic started by: T-hane on December 06, 2005, 08:47:03 pm
Title: Safe RPM
Post by: T-hane on December 06, 2005, 08:47:03 pm
In my car i have the a gear box code of AGS and i find the gear ratio to be great for driving in town.  But on the hi-way at 120km the car is at 3000rpm is that kind of rpm safe for long periods of time?
Title: Safe RPM
Post by: QuickTD on December 06, 2005, 09:04:24 pm
3000rpm is fine. I routinely cruise for hours at 3200rpm (135km/h) on the highway. My car now has 285000km on it, consumes no oil and starts instantly at -25šC.
VW industrial engines are often set up to run 3600rpm on 2 pole generators, they run at this speed under full load for years, not fun to listen to but it doesn't appear to harm them... I wouldn't sweat it.
Title: Safe RPM
Post by: Black Smokin' Diesel on December 07, 2005, 03:28:06 am
It's actually more harmful to an engine to leave it idling for hours than driving it on the highway. Unless you're scared that the timing belt won't survive or you have cooling problems, there's really no problem.
Title: Safe RPM
Post by: T-hane on December 07, 2005, 05:21:03 pm
at that rpm what should i be seeing for fuel millage im  only gettng about 550 to a tank right now running 3000rpm on the hi-way.
Title: Safe RPM
Post by: NOTORIOUS VR on December 08, 2005, 02:10:52 am
Hmmm... I'd like to know as well.. I have the 4S tranny in my car (or so it says on the housing of the tranny), and @ 120 km/h i'm at 3200 rpm... which I thought is a little high...
Anyone else here with a 4S tranny that can confirm? 8)
Title: Safe RPM
Post by: carrizog60 on December 08, 2005, 10:38:25 am
i also have a 4S but at the moment the car is being rebuited and i never drive it before...
120km/h at 3200 itīs kind high...
 :cry:
Title: Gearbox check
Post by: Mark(The Miser)UK on December 08, 2005, 11:28:27 am
Why not lift one front wheel and put it into 5th gear and check for one crank revolution whilst turning wheel...
Title: Safe RPM
Post by: Dr. Diesel on December 09, 2005, 01:47:18 pm
i put the 3.67:1 ring and pinion in, and an .71 fifth gear. 2450 rpm at 100km/h.
Title: Safe RPM
Post by: BlackTieTD on December 09, 2005, 02:10:59 pm
about time! we should go for another hwy drive now.  :)
Title: Safe RPM
Post by: jtanguay on December 09, 2005, 02:55:37 pm
Wouldn't it be nice to have a 6 speed tranny?
http://www.autoshoppingcenter.com/Volkswagen/transmissions_rearend/trans_6speed.html
these would fit pretty much all mkII right? $$$$$$$$$$ though :(
btw, I used to drive a 3 speed automatic golf gas...  3500 rpm at 100km/h very low mpg :(
Title: Safe RPM
Post by: Maarten on December 09, 2005, 02:58:38 pm
6-Speed Race transmission
Race transmission for 4 Cylinder applications.
Custom 1st through 6th gears
limited slip differential installed
I'll take this one, take away please  :roll:
Title: Safe RPM
Post by: djteam on December 10, 2005, 12:31:34 am
Hi,
I took an Tranny of an 90HP TDI Engine, now iīm at about 150km/h@3200.
Itīs a cheap way to get RPM down.
christian
Title: Safe RPM
Post by: VWRacer on December 10, 2005, 09:38:30 am
Just a note to those enchanted with the idea of a 6-sp manual trans...the only real advantage of 6 gears over 4 or 5 is in racing where more gears allows for better acceleration. For maximum economy the primary factors are the r&p ratio (lower number is better), the top gear ratio (lower number is better) and the drive-wheel diameter (higher number is better). Dr Diesel's solution above will yield the best fuel economy, no matter the allowed top speed.
Title: Safe RPM
Post by: jtanguay on December 11, 2005, 12:18:40 pm
Quote from: "djteam"
Hi,
christian
How much did that cost you?  Which TDI trans will fit a MKII IDI engine???  Sounds like it could be a simple swap :)
Title: Safe RPM
Post by: NOTORIOUS VR on December 12, 2005, 01:49:03 am
Any 4cyl VW tranny will fit another 4cyl VW engine... the only thing I could see that you'd have to change is the pedals for the newer hyrdo tranny.
Title: Safe RPM
Post by: djteam on December 12, 2005, 03:51:18 am
Hi,
basicly, like NOTORIOUS VR Said, almost any 4zyl. Tranny will fit. You donīt have to switch to hydro. clutch. you can convert the 5 cylinder Tranny to mech. clutch.
But you have to witch the shiftbox to a cable box. (e.g out of an G60).
Price:
Tranny 100€
Clutch 150€
Small parts 250€
christian
Title: Safe RPM
Post by: jtanguay on December 12, 2005, 07:08:01 am
hmmm yes a hydro tranny would be very nice!   a very smooth ride.   I guess all I would need is the master cylinder for it since the slave cylinder is right on the tranny?
btw a 6 speed trans would be nice, if the first 5 gears could be the same as what I'm using now, and maybe 6th gear could be set to cruise at 120km/h @ 2k rpm or so.   but dream on :(
Title: Safe RPM
Post by: carrizog60 on December 12, 2005, 12:41:19 pm
Quote from: "Dr. Diesel"
were to get these?in europe
Title: Safe RPM
Post by: LeeG on December 12, 2005, 09:45:29 pm
Quote from: "T-hane"
1991 Jetta TD (AWY tranny? too dark to go check)
in 5th gear:
2500 rpm = 92 km/h
3000 rpm = 110 km/h
3500 rpm = 130 km/h  and yes it is happy to stay there as long as I have ever been able to keep it there.
Car has 385,000 km, average economy over last 120,000km is 5.8 l/100km. A bit better in summer than winter.   Thats a 110 km round trip commute with an average speed of 85 km/h...anywhere from stop and go to 130 + km/h.  I beat on it pretty hard at least a couple times a day, a gentle driver could probably wring a bit more out of it.
and if anyone cares:
In 3rd, it stops pulling at 4000 rpm at 90 km/h
in 4th at 3750 rpm at 120 km/h
in 5th, I have never pushed past 140, but it is still accelerating.  I once saw a PDF of a VW chart showing a Vmax of 155km/h.
Title: Safe RPM
Post by: T-hane on December 13, 2005, 02:54:03 pm
i figure that i get about 33 mpg is that good and thats 3200rpm on the hi-way
Title: Safe RPM
Post by: BlackTieTD on December 13, 2005, 03:05:57 pm
Quote from: "LeeG"
i've had mine buried past the 160km/h on the speedo... i estimate 170km/h. that is FF gearbox with 1.6L TD motor from a 1990 Jetta. it still had more :)
i wouldn't say so. i get 42MPG and i usually travel at about that RPM.
Title: Safe RPM
Post by: jtanguay on December 13, 2005, 09:43:20 pm
I would really love a six speed tranny, with maybe some lower gear ratios for the lower gears, and 6th gear could give the car the ability to go 180km/h at around 3500 rpm or so.    Gotta love how the fuel consumption on a diesel is more relative to rpm than a gas car.
Title: Safe RPM
Post by: MrDave on December 15, 2005, 11:50:01 am
Tranny options:  (rpm@speed for 195-50-15 rubber)
European 02M TDI 6spd:  2.61FD with .805 6th = ~1950 rpm at 100kph.
A3/B4 TDI 02A tranny:  3.16FD with .76 5th = ~2200 rpm @ 100kph
A4 TDI 02J tranny:  3.39FD with 0.76 5th = ~2400 rpm @ 100kph
5th gear options for 02A/02J:  0.71, 0.68, 0.65
Link (http://forums.tdiclub.com/showthread.php?t=119288)
VWMS R&P for 16V 020:  3.32FD with .71 5th = ~2200 rpm @ 100kph
Link (http://www.autotech.com/prod_drive_transgear.htm)
Tallest 02J/02A:   3.16FD with 0.65 5th:  1900rpm@100kph (but big jump between 4th and 5th)
Notes:
020 is rod-shift/cable clutch and pretty weak.
02A/02J are cable shift/hydro clutch, but can be run as cable clutch
02M are cable shift/hydro clutch.
02M is the dual R&P 5&6spd tranny.
HTH.
-Dave
Title: Safe RPM
Post by: entuzijast on December 15, 2005, 03:34:43 pm
I have a question...
My Eco diesel Golf, with stock fuel pump had 160 max speed...Then, I changed the pump to real TD, and he still goes 160...
Now, I have tachometer, and, by 160 km/h, I have 4000 rpm...Shouldn't it go up to 4500 rpm or more?
I also feel huge loss of power when i hit 4100 rpm in any gear, it's like the car hit the wall, so I'am wondering is this normal, is the problem in fuel pump, tranny or my tachometer is wrong?
Title: Safe RPM
Post by: DVST8R on December 15, 2005, 03:56:33 pm
Time for the Govoner mod.  :wink:
