Engine Specific Info and Questions => IDI Engine => Topic started by: deathhare on May 10, 2010, 04:31:42 pm
Title: How much boost are you running without IC?
Post by: deathhare on May 10, 2010, 04:31:42 pm
Over the weekend I finally installed my boost gauge in the car and to my surprise its hitting 11psi.
I had planned to add an IC before long but now Im thinking i need to asap?
Just curious what boost levels people are running without ICs?
(http://i75.photobucket.com/albums/i292/deathhare/DSC_0027.jpg)
Title: Re: How much boost are you running without IC?
Post by: rallydiesel on May 10, 2010, 04:40:24 pm
17-18 psi.
Post by: burn_your_money on May 10, 2010, 05:13:10 pm
Stock is 8-12 PSI so you are still well within safe limits.
Post by: deathhare on May 10, 2010, 05:19:37 pm
Great. I always thought it was more like 7psi.  ;D
Shows what I know.  8)
Still want an IC. :-*
Post by: vanbcguy on May 10, 2010, 05:29:52 pm
I run mine about 15-16 PSI... Still definitely want an intercooler though.
Post by: AudiVWguy on May 10, 2010, 06:58:36 pm
-------------Temporary Thread Hijack-------------
Wow, amazingly clean engine bay!!
You win this months Giant Q-Tip award
----- we now return you to our regularly scheduled thread..............
Post by: ezekiel on May 11, 2010, 12:43:07 am
Got a filter on that turbo?   ???
Post by: deathhare on May 11, 2010, 04:08:43 am
Thanks, yeah the motor has just gone in and so clean as I could get it. Still not "new" clean.
Yeah there is a filter on the turbo.
Post by: arb on May 11, 2010, 06:28:02 am
8 - 9 psi. I have a 2" aluminum loop around the parimeter of my Dodge caravan engine compartment which gives some kind of IC one would think, after I finish the job and have a proper IC, I'll increase the boost and fueling a bit.
Post by: Rabbit on Roids on May 11, 2010, 08:47:09 am
i ran 25 psi without an intercooler all the time. i would spike it to 35+ from time to time.
Post by: Kantdrivefast on May 11, 2010, 10:12:56 am
15-18psi without
Post by: vanbcguy on May 11, 2010, 08:59:52 pm
I'd be more worried about the lack of timing belt cover........  What'd I see someone say somewhere, "Running your engine without a timing belt cover is like strapping a grenade to it with dental floss instead of a pin"
Post by: Rabbit on Roids on May 12, 2010, 10:06:47 am
ive personally never seen an engine die from no timing belt cover.
ive killed an engine from having the air filter pop off.
someone else on the board has murdered their compression from losing an air filter too..
Post by: arb on May 12, 2010, 02:33:54 pm
All's it takes is that "Silver B B" as they said in Nam....  I look at it more like going to the red light district in amsterdam w/o protection ;-)  At some point you'll get bitten.
Post by: zagarus on May 12, 2010, 02:41:08 pm
I recall running 15psi with no intercooler on my 1.6TD with a T3.
Post by: RabbitJockey on May 12, 2010, 04:20:21 pm
you can up the boost and be ok, it could possibly make it run cooler egts.  but i wouldn't recommend cranking up the fuel and the boost a lot,  i was running 25-30 psi and plenty of fuel with no intercooler i did have a larger exhaust and cone filter but other wise there weren't any other mods.  i ended up with a cracked head,  you don't want to end up where i ended up haha.  i was young and dumb what ever.  honestly with out you increasing fueling, you probably won't be able to go over 15 psi.  there just won't be enough heat and gasses to do it.  so i'd say ur safe to up boost  just keep ur egts in check
Post by: vanbcguy on May 12, 2010, 11:39:48 pm
There have DEFINITELY been dead engines around here due to no timing belt cover.  There have DEFINITELY been engines who've died due to no air filter too!!  Both are equally bad news...  One gets you gradually over time, the other reaches out one day with a totally unexpected godsmack.  Either way, eventually you're doing a rebuild way sooner than you would have otherwise.
Post by: burn_your_money on May 13, 2010, 04:45:04 am
Don't worry, he has a timing cover (finally) :-*
Post by: deathhare on May 13, 2010, 05:24:45 pm
Yeah thanks to this guy I have one. :)
I didnt say it was on the car though.  :P I'm trying to get it nitro plated at the moment to put it on.
And Ive always had an air filter. Its there in the pic you can just barely see it.
Post by: 2mAn on May 13, 2010, 05:50:37 pm
on my old TD coupe i was running 20psi. ill be taking it a lil easier on this coupe until i get an intercooler. old motor had a 2.5" PP downpipe and straight pipe exhaust. this new one is all TT stuff 2.25" im excited. so glad to be back here  ;D
Post by: catlin_cava on May 13, 2010, 06:00:26 pm
I was running 20+ PSI on my Last AAZ with no intercooler.
Post by: GEE-BEE on May 14, 2010, 08:39:16 am
17 PSI here....
it's just a hauler....
GB
Post by: kaneb on May 14, 2010, 02:48:18 pm
I usually don't go past 15 psi but it will spike to 21 psi if i get on it.
Post by: deathhare on May 16, 2010, 12:17:10 pm
Did a 600 miles round trip this past weekend with no issues. A LOT of mountains and long climbs on boost without any issues.  ;D
Post by: burn_your_money on May 16, 2010, 05:50:53 pm
Pics or it didn't happen. :)
Post by: MouseGTD on May 17, 2010, 03:01:17 pm
i was running 30psi+ for a good while till i got my boost controller now its around 25psi.
i've been running mine without a filter since i put the engine in over a year ago and had no problems what so ever. kept meaning to put one on but never got round to it and very much doubt i ever will. I also ran my old td scirocco for a year without one, both cars had plenty of abuse and were driven in all weathers and on lots of different sufaces from tarmac to gravel.
i've ran a few car's without cam belt covers and know many other's who have done the same and i have never heard of any engines being killed by it. whats supposed to be the danger?
Post by: vanbcguy on May 17, 2010, 05:10:01 pm
With the timing belt, if ANYTHING and I mean ANYTHING from a tiny little pebble, a twig, parts of a bird that just went through you grill, that zip tie you left sitting on top of the radiator, some random bolt, WHATEVER gets between the belt and a pulley (which the toothed belt will drag in there quite nicely) you've got a very good chance of throwing the belt.  Once that happens you're rebuilding your head at a minimum since you just smashed your pistons into your valves.  If you're lucky it's just the head, if you're unlucky you could be in for a whole bottom end.  Personally I don't have an extra couple grand sitting around "just in case".
With respect to the air filter, well... Someone once told me if you don't have anything nice to say, don't say anything at all.   :-X :-X
Post by: Smokey Eddy on May 17, 2010, 10:25:23 pm
I tried 25psi once without an IC and my car actually got slower.
Post by: MouseGTD on May 18, 2010, 03:32:14 pm
does removing the cam belt cover suddenly turn your car into a magnet for low flying birds? lol
as i say i've never heard of an engine being damaged by a lack of a cover, some of the car's running without them are running twin carbs with trumpets and no filters too
some one best tell this bloke that his engine will explode if he drives it like that ::)
(http://img.photobucket.com/albums/v336/Miguel-Newera/IMG_0680.jpg)
running no filters or cam cover is a common practice, i could fill this thread with photo's of car's running without one or both but the threads gone far enough off topic as is.
Post by: vanbcguy on May 18, 2010, 08:41:48 pm
Remember, not every engine has a flat cylinder head and pistons with no room for valves.  Many many many gassers are non-interference engines, or are so slightly interference that they can suck it up with their hydraulic lifters in a lot of situations.  There are lots and lots and lots of these on this board:
(http://i197.photobucket.com/albums/aa85/vwaldon/piston_with-imprint.jpg)
I mean LOTS.
As to the bird, that was a joke... just ask this guy: http://www.vwdiesel.net/forum/index.php?topic=17883.0 (http://www.vwdiesel.net/forum/index.php?topic=17883.0)
