For Sale/Looking For => Parts for Sale/Wanted => Topic started by: ashleyroe on May 07, 2010, 04:36:46 pm
Title: ASAP! WTB: reverse switch for an 84 rabbit, 4 speed.
Post by: ashleyroe on May 07, 2010, 04:36:46 pm
6 pin reverse light switch for a 4 speed rabbit.
pin inside broke and my reverse lights won't go off  :(
show me what you have!
thanks  :-*
Title: Re: ASAP! WTB: reverse switch for an 84 rabbit, 4 speed.
Post by: ashleyroe on May 07, 2010, 05:54:52 pm
bump
Post by: ktzdsl on May 07, 2010, 06:12:29 pm
Do you have a pic of the switch? I can check our stash tomorrow morn to verify. Do you need the switch connector at the cable or the switch off the transmission?
Post by: ashleyroe on May 07, 2010, 06:23:11 pm
the one all the way to the right (6 pin):
(http://www.brokevw.com/08-18-09%20001s.jpg)
(http://www.brokevw.com/08-18-09%20003s.jpg)
Post by: ktzdsl on May 07, 2010, 07:41:52 pm
Will check and respond to you by 10AM CST tomorrow.
Post by: fatmobile on May 07, 2010, 08:19:36 pm
The next one will die too.
 They can't handle the current of the reverse lights,..
 sooo Relay it when you get a new switch,..
 or make your own lever switch outside the trany,
 that the lever bumps when you go into reverse.
Post by: ashleyroe on May 08, 2010, 03:53:10 am
thank you!
Post by: ktzdsl on May 08, 2010, 07:50:01 am
Found two (2)  switches but not of the correct gender......they are five (5) point like in the middle switch in your pics. Going to storage now to check there. Sorry.
Post by: ashleyroe on May 08, 2010, 08:26:52 am
i contacted broke, he has one for me. i'm also gonna try a 5 pin and see what it does.
thanks though!
if you do come across a 6 or if anyone does let me know, i still want 'em.
Post by: Rabbit on Roids on May 08, 2010, 08:48:51 am
the one with more pins is for the up shift indicator if i remember right.. and i thought the one with more pins is for a 5 speed? guess not..
Post by: ashleyroe on May 08, 2010, 09:13:22 am
no. cause that 5 speed one also works for the upshift light. suposidly the 5 pin one is the replacement for my six pin one.
but get this!
my reverse switch is unplugged right now, and my upshift light is still working....
might be because the way i ran my tach...
Post by: ktzdsl on May 08, 2010, 10:18:49 am
No other switches here. Glad you were ale to find one.
Post by: ashleyroe on May 08, 2010, 11:14:43 am
thanks anyway!
Post by: fatmobile on May 08, 2010, 11:19:48 am
What's the trany code for this rare bird?
Post by: ashleyroe on May 08, 2010, 11:26:35 am
i have a 4A.
Post by: Rabbit on Roids on May 09, 2010, 08:55:20 am
thats the trans thats supposed to come in an 84 diesel if i remember right..
Post by: ashleyroe on May 10, 2010, 04:10:27 am
yes it is.
http://a2resource.com/eandt/ratios.html (http://a2resource.com/eandt/ratios.html)
