Engine Specific Info and Questions => IDI Engine => Topic started by: GTD. on April 28, 2010, 03:16:43 am
Title: weird fueling problem
Post by: GTD. on April 28, 2010, 03:16:43 am
Fitted a digifant GTI tank lift pump
now when I put the ignition on I see fuel going though the pump return line but the feed line is often empty turn ign off and the fuel back feeds up the feed line.
theres a little bit of fresh fuel on the filter arround the pre heater fitting
if I wiggle the inlet hose at the banjo when it starts the feed hose fills with frothy fuel
do i have a blockage in the pump feed hose and a dodgy seal on the preheat fitting?
looked for new clear feed hose on ETKA ETOS but it looks like they are deleted :-[
Title: Re: weird fueling problem
Post by: Rabbit on Roids on April 28, 2010, 09:13:22 am
restriction somewhere.. thats the only reason i can think of. or you simply have an air leak and its loosing prime..
