Engine Specific Info and Questions => IDI Engine => Topic started by: Luckypabst on April 21, 2010, 08:20:08 pm
Regarding the later style rubber Vanagon engine mounts, I'm looking for a few dimensions.
First, I need to know the distance from the center of the 10mm center bolt to the inboard side of the metal casing.
Next I'd like the dimension from the center of the 10mm bolt to the center of the locating nub.
Finally, if someone has it, I'd like to know how far the head of the larger (12mm?) mounting bolt protrudes beyond the edge of the metal casing.
The attaced photo might help illustrate what I'm after...
Thanks
Chris
(http://i6.photobucket.com/albums/y218/luckypabst/motorlager.jpg)
Later ones...
May have these off at the weekend on mine, if so I'll take some measurements for you.
MM
Thanks fellers...
Much appreciated! I can't bring myself to spend $60 just to take a couple of measurements.
Chris
Any luck, MM?
I'm sure I've got some loose ones kicking about here. I'll look later today.
now i feel like a bit of a donkey, forgot all about this until finding the thread again just now :(
sorry aboot that, I had the engine out too so I could have done this easily!! :-[
I have an engine mount in the cellar, I could measure centres on the stud hole to the nub locating hole from that?
Is the main stud not central on the whole piece?
I'm not really sure... I'm kinda betting that VW used the same outer shell as the early style mounts, turned 90 degrees with changes only to the internal part of the mount. I just need to verify one way or the other...
Thanks
Chris
I figured out that Audi A4's and A6's w/ manual trans. use the same mount for the trans.
So maybe there is some better derometer for those mounts?
Last attempt...
Anybody?
Chris,
I just measured the bracket I have, dim B is 25mm. I would guesstimate that dim A is 35mm.
Hope this helps, sorry again i forgot when I had the engine out :-[
What is your last question about the 12mm head, I dont entirely understand? Sounds like you are just asking for the depth of the bolt head??
Thank you much!
Just so we're on the same page - you're measuring the two holes in the aluminum "arm", correct? This would be the later arm that has the small locating hole drilled inboard of the larger mounting hole, as well as the two little locating tabs extending off toward the front?
Regarding the other question, I'm curious how much clearance is required to accommodate the head of the mounting bolt beyond the edge of the rubber mount. I can estimate this if all else fails.
Chris
Not sure about the 2 tabs, Ill take a looky again tomorrow, but yes hole wise. Yup its the later style (1990).
I see what you mean with the bolt bit now, I can look on my van in the morning and check that out no probs (if i remember! ;D)
Cool deal...
I'm not worried about the two tabs.
It's much appreciated!!
Chris
didnt go near the van yesterday cos it was raining, I'll have a look this morning (uk morning!) for you chris.
mm
Chris, apologies for the delay, life kind of changed my plans for me over the past 2 weeks!
Im having a play this afternoon, do you still need these dims?
Cheers, MM
Don't go out of your way!
I've been too busy to approach this project for a while... but very a rough check with the dimensions you already provided shows that the early and late mounts are likely the same in the critical spots, just rotated 90 degrees from one another.
Thanks
Chris
