General Information => Troubleshooting => Topic started by: blackbird82 on April 13, 2010, 10:12:30 am
Title: Miss after slight runaway
Post by: blackbird82 on April 13, 2010, 10:12:30 am
Hey I have a 94 AAZ Jetta. I was cleaning and re-sealing the intake top.(the upper half of the manifold, it was leaking at the gasket between the two halves.) And I guess some carb cleaner got in the intake, when I had it all done and fired it up. it ran and then a few seconds later sucked up the cleaner. hello revS!
It revved pretty high and then calmed down.  I shut it off and re-started it. And ever since it seems to have a slight miss at idle when cold.Although when hot, it stil has a slight stumble.  Rev it up and it runs great. Starts immediately.
Changed injectors and went from single spring to double spring. Didnt change it, although less smoke.
All glow plugs great. when I had the injectors out, i ran em and they got nice and cherry
Pete
Journeyman tech. John deere ag systems
Title: Re: Miss after slight runaway
Post by: blackbird82 on April 13, 2010, 01:27:54 pm
on a side note. I thought it was injectors. Cause it would miss when cold, but hot idled fine with a bit of nailing.  I changed em out with a set of dual spring injectors rebuilt with 297 nozzles and 150 bar. now it doe sth estumble a bit when hot. only sometimes!
Post by: Vincent Waldon on April 13, 2010, 02:43:01 pm
How much liquid carb cleaner do you think the engine ingested??  I ask because anything more than 20cc could have bent a rod, giving you poor compression in 1 or more cylinders... smoke, starting issues, etc.
Post by: blackbird82 on April 13, 2010, 02:49:16 pm
hmm could've been an amount close to that.  That is a possibility, although, it sure burned it good! I have rebuilt some small yanmars that did that, have low deck heiht after ingesting hydraulic, when a seal went
they smoked white all the time, and it was only one cylinder. I don't smoke white at all!
Post by: Smokey Eddy on April 13, 2010, 05:08:16 pm
Interesting. Have you tried advancing the timing a SMIDGE to see if that clears it up?
loosen your pump up a bit (keept it snug) and i like to take a very soft rubber mallet and gently knock the pump towards the head JUST until it idles fine. Very very touchy business. Be careful and patient.
Post by: blackbird82 on April 13, 2010, 08:59:57 pm
never loosened the pump on these. are the bolts the ones on the inside that you get through the pump pulley?
Post by: burn_your_money on April 14, 2010, 03:04:40 pm
You put 294s in a dual spring body? That could be your problem, although I wouldn't expect it on just one cylinder.
Post by: blackbird82 on April 15, 2010, 08:22:24 am
I have to double check. i think they were 293's iput in there.  The old single springers had 297's in them. It didn't miss at idle with them when warm or even a little better than cold. they were a little weaker opening pressure (147 vs. 150). I just wonder if its all timing and fuel delivery.  I have always wondered if you have 2 springs(delivery and injectors)how if one is off it would afffect the other.
Plus at what rpm should advance take over from the cold start handle. At like 1600rpm if I pull the handle it still advances it, and revs it up to 1800!
Post by: Vincent Waldon on April 15, 2010, 08:41:27 am
The cold start advance is ignored by around 2000 RPM... and it's only a couple of degrees of advance to begin with.
On many pumps however, the cold start lever is tied to a "fast idle" lever which ups the idle speed when you pull out the cold start handle... this may be what you're experiencing.
Post by: blackbird82 on April 15, 2010, 09:00:19 am
Mine never idles higher with cold start. Its newer than that. true at around 2000 spm it is not effective. But from what it does in the mids (1200-1400) it would suffice to me that the pump is not advancing fast enough. hmm, i need to get another out bolt for the pump and drill and tap and put a DR port on it.
Post by: blackbird82 on April 16, 2010, 08:27:28 am
after more testing last night! my cold start handle still advances the timing up to 2500rpm. i can tell from the sound. and it will make it speed up a hair. that to me is really high, pump should be advancing tiself before that.
Post by: vanbcguy on April 16, 2010, 09:53:36 am
Definitely not a good sign...
Try hagar's "pull test" - find a fish scale and see how much force it takes to pull the cold start engine while the car is off, then try again after starting it, and once more at 2K RPM.  The force required to pull the cold start handle should decrease quite a bit if the pump's internal pressure is good, especially by 2K RPM.  A "good" pump should be a ratio of 5:1 or more (IE if it takes 5 lbs to pull the handle when the engine is off it should only take 1 lb when the engine is running, your numbers will be different).
If it's a low ratio (not much difference in force) then the pump's timing piston is either stuck or the pump's pressure is way down.  Just an easy test to get a "handle" on things!
Post by: blackbird82 on April 18, 2010, 07:59:59 am
yeah I can feel the difference when driving vs sittin with the motor off. I need to get myself the tools to test and check and set timing.
Post by: blackbird82 on April 23, 2010, 05:53:04 am
after more lookin into it, i can see that pump pressure is gonna be my main culprit. what is the best way to measure. i was thinking of gettting another out banjo bolt and drilling and tapping for a fitting. what have you guys done?
Post by: vanbcguy on April 23, 2010, 09:09:13 am
The best solution I've seen is using the extension pedestal from an NA pump and tapping it for a gauge.  That way you have the same OUT bolt in use for your measurements, as it is part of the pressure regulation system.
Post by: rabbitman on April 23, 2010, 10:11:26 am
You gotta use an OUT bolt when checking, and drilling through it will ruin it.
Post by: blackbird82 on April 23, 2010, 12:28:42 pm
what is this extension pedestal. sorry my lack of knowledge. have never seen a NA VW
Post by: vanbcguy on April 24, 2010, 10:52:25 am
Check out this link:
http://www.vwdieselparts.com/forum/viewtopic.php?t=5936 (http://www.vwdieselparts.com/forum/viewtopic.php?t=5936)
All will be answered!! :D
Post by: blackbird82 on April 25, 2010, 10:44:17 am
I see, hate to say it. But where the heck would I get one. anyone wanna sell me stuff? There are no dead vw's around at all. stuff is raided, or like a few years ago. anythin dead went to the scrapper for metal prices.
Post by: truckinwagen on April 25, 2010, 11:27:05 am
I have one of the shorter pedestals that I was going to make into an adapter for a pressure gauge, but never got around to it.
you are welcome to it.
Post by: blackbird82 on April 25, 2010, 03:46:46 pm
That would be great. how shall i pay you for it. To ship from alaska to me
Post by: truckinwagen on April 25, 2010, 04:15:38 pm
paypal works good, PM me your address and I'll let you know.
it should fit in an envelope, so shipping will be very minimal(probably not enough to worry about payment for...)
-Owen
Post by: blackbird82 on April 26, 2010, 05:52:04 am
well my e-mail is [email protected]
my address is
Box 508
Teulon, manitoba
canada
R0C 3B0
