General Information => General => Topic started by: apriliaandy on November 24, 2005, 05:26:25 am
Simple stuff folks, but there are an assortment of nuts around the gearbox and I wanted to make sure which was which. I was under the impression that the drain plug was a 17/19mm hex but the VW garage said not. Also where is the fill hole....3ltrs correct?
Regards
The plug is a 17mm hex (you can use a wheelbolt to unscrew it)
Fill it up till there is olie dripping out of the hole, I think 3 liter is too much.
appreciated.
