Engine Specific Info and Questions => IDI Engine => Topic started by: BlackTieTD on May 07, 2004, 08:35:06 am
Title: 1.5L oilpan on 1.6TD
Post by: BlackTieTD on May 07, 2004, 08:35:06 am
i asked in the old forum, but i'll bring the question over here..
1.5 diesel engines had shallower oilpans, giving more ground clearance than 1.6TD oilpans.
will a 1.5 oilpan fit on a 1.6TD (MF code) and work properly? i imagine the amount of oil the engine will hold will decrease.... other than that i'm clueless about this.
any thoughts?
Post by: fspGTD on May 07, 2004, 09:50:30 am
I'm not sure if a 4-quart pan is actually any shallower... with the oil pump pickup being located in the same spot on both pans (gotta be close to the lowest point, don't ya think?), I think the 5-quart pan is just wider at the bottom.  But it might not actually stick down any more than the 4-quart (or there may be a slight difference, but likely not much.)
The reduced oil capacity will also make your oil temps run higher.
That said, to make a 4-quart work on a turbo diesel, you'd have to drill a hole into the side and add an oil return fitting of some sort, like is on the TD pan.
Post by: BlackTieTD on May 07, 2004, 10:30:03 am
if there was a straight swap for a shallower pan i'd do it... but that's not worth the work.
(now watch, i'll come on here a week after i lower my car posting "i took out my oil pan!!"  :lol: )
Title: Re: 1.5L oilpan on 1.6TD
Post by: fatmobile on February 10, 2026, 04:48:12 pm
 Just took a trip to the last page.
 There was a short oil pan on some of the 1.5 engines.
fspGTD hasn't posted since 2006.
 Sometimes I wonder what he's up to and where his car ended up.
 Great info on his posts. First person I knew that put a VNT-15 on a 1.6 engine, then used it to autocross.
Post by: BleachedBora on February 24, 2026, 11:11:44 am
That's pretty slick, neat setup!
