General Information => Troubleshooting => Topic started by: rs899 on January 31, 2010, 04:16:34 am
Title: Advancing Pump Timing - quick n dirty?
Post by: rs899 on January 31, 2010, 04:16:34 am
OK- I have the formerly trashed 91 Jetta running reasonably well now, but I am sure the IP timing is retarded because it runs sluglike compared to my Caddy and when I pull the cold start it picks right up and sounds nice.
So, I tried to advance it, but the IP has run out of room towards the block.
I need to advance the pump by one tooth, then go from there.  I think this means  holding the belt in its current position, then rotating the pump clockwise one tooth, correct?
How do you guys do such a thing without upsetting cam and crank timing?
Rick
Title: Re: Advancing Pump Timing - quick n dirty?
Post by: theman53 on January 31, 2010, 06:31:52 am
I don't believe that you can. Best would be to retime with the dial indicator. Unless someone else knows better.
Post by: Rabbit on Roids on January 31, 2010, 09:04:10 am
i would advise AGAINST doing what you said. if you do one whole tooth, you probably wont be able to retard it enough to run right.
Post by: rs899 on January 31, 2010, 03:33:48 pm
Ok, technique aside, for the time being.  There has to be a way for this thing to run with the "proper" advance.  I used a dial indicator on it and it's right around 1mm right now, but it obviously needs more advance.  Maybe I didn't read it right ?( I have done it countless times, but never on this car).
What's wrong with advancing a tooth and then pulling the pump towards me?
Post by: dennis on January 31, 2010, 04:16:02 pm
Might want to check internal pump pressure.
Post by: rs899 on February 01, 2010, 10:14:24 am
Thanks Andrew-
In fooling around for 16 years with my Caddy, I never have had to deviate from using the dial indicator reading as gospel.  But this time with this Jetta, I am going to have to do more of a seat of the pants setting to get it running better.
I am a little nervous doing it this way, but am I correct in thinking that as long as my cam and crank are dead on with each other, having timing a tooth off one way or the other (until I dial it in by feel) will not damage anything?
Rick
Post by: rs899 on February 01, 2010, 11:02:48 am
OK, so thinking ahead, if I fudge it this way and get it to run better, I presume I will end up with more lift than the book says I should have, but what?
That complicates my future timing belt changes ( if I use the same IP).  I guess I will need to eventually record what the dial indicator "sweet spot" reading is for this pump. Any better ideas?
Rick
Post by: Vincent Waldon on February 01, 2010, 11:53:03 am
I think that's a very reasonable approach.  The dial indicator method doesn't account for cam wear, injector pressures etc,  so sometimes needs a bit of tweaking... but its advantage is that it's reproducable.  If you manually find where your engine runs best and then measure it you'll have dialed in your specific pump/injectors/etc in a reproducible way.
Post by: rs899 on February 02, 2010, 04:14:21 am
It occurs to me that I just need to remember to record the lift with the dial indicator on the old belt when I go to change it 3-4 years from now.  Now, the problem is trying to figure a fail-safe way to do that- perhaps a yellow sticky in the Bentley?  Except that having done this so often, I may not even look at the Bentley....getting old sucks. :'(
Rick
Post by: Rabbit on Roids on February 03, 2010, 07:52:20 am
write it on the wall of your shop. thats where i write stuff that i dont wanna lose.
Post by: 8v-of-fury on February 03, 2010, 08:09:10 pm
I keep a notebook in my tool box ;) I'm only 20.. but i still have a memory like sieve sometimes lol
Post by: rs899 on February 04, 2010, 03:50:35 am
Maybe I'll put a note on the strut tower.  If I use a permanent marker, though, it might eventually fade due to diesel and solvents- probably have to use paint.
Post by: ein bora on February 07, 2010, 06:50:35 am
The flywheel on my 1.9 IDI has two TDC marks, apparently the same flywheel is used on some gassers so the second mark is 6 degrees BTDC. When I first set the timing up of coarse I had the wrong TDC. The car ran but I had to run the pump all the way up to advance it as far as I could - and had issues like you described. When I finally figured it out, now it sits where it should and runs as it should. Not saying you have the same issue, but maybe worth checking out.
Post by: rs899 on February 07, 2010, 03:04:28 pm
I think my flywheel is OK, since I had the head off a few weeks ago and it looked like TDC was where I expected it (but I know the gasser flywheel you are talking about and I agree it is confusing).  I slipped the IP one cog advanced and now it runs better- and I used up almost that whole cog.  I haven't measured it with a dial indicator- I am curious to find out what it is.
Post by: Rabbit on Roids on February 07, 2010, 07:19:16 pm
i had that problem too, as i used a gasser flywheel, and it had only gasser timing marks.
Post by: wolf_walker on February 07, 2010, 07:20:12 pm
As was mentioned if the internal pump pressure is squat even at idle it'll run funny.  Pressure = advance.  Somebody might have jacked with it previously.  Something has to be pretty funky to need that much advance.  It's better than it not working, but there's got to be a reason.
