General Information => General => Topic started by: anto on January 29, 2010, 04:19:07 am
Title: Testing an egt gauge
Post by: anto on January 29, 2010, 04:19:07 am
Recently bought an egt gauge with no instructions and not even a clue as to who made it.
Gauge lights up fine, needle moves when current is added to it but when i hooked up the probe and put heat to it, no movement whatsoever.
I was using a lighter to heat it, would that be sufficient?
thanks,
Anton
Title: Re: Testing an egt gauge
Post by: 8v-of-fury on January 29, 2010, 07:36:13 am
thanks,
Anton
What is the lowest number on your gauge?
You do realize this gauge is for measuring Exhaust Gas Temps in the range of anywhere from 400-1600F
I don't think the flame of a lighter could get anywhere near those temperatures..
Post by: anto on January 29, 2010, 08:01:34 am
Thats what i thought 8v but surely a flame is plus 100degrees C is it not.
i think i will just fit it to the manifold and try it there.
Post by: blackdogvan on January 29, 2010, 09:29:08 am
Typical candle or lighter flame temp is 320-875 deg C (600-1600 F) depending where in the flame you measure.
Post by: 8v-of-fury on January 29, 2010, 01:12:56 pm
I have to disagree. That seems like way to hot. I have been burned by candle and lighter before.. and even 600f would cause 2nd or 3rd degree burns I'm sure.. Assuming the hottest part of the flame is 1600f does this mean it will melt one of our pistons if held there long enough?
I just measured a lighter flame with an infrared thermometer and got 63 degrees Celsius. The size of the flame determines the heat.. I happen to have a lighter that is turned up to be a flame thrower practically.. and it checks out at 110c with a 4" flame
Post by: 745 turbogreasel on January 29, 2010, 01:21:14 pm
stick in in the oven at 450F.  you could wrap some foil around the wires where you close them in the door.
If it is an electronic gauge, grounding is crucial.
Post by: blackdogvan on January 29, 2010, 02:12:56 pm
What temp does your infrared thermometer display when you point it at the space between your ears?? :P
Post by: 8v-of-fury on January 29, 2010, 05:09:25 pm
36 Celsius pointed at my forehead :P
I just don't see how a flame is 600deg C.. especially a small butane flame that is a 1/2"
