Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: DieselVanagon on January 09, 2010, 10:10:00 pm
Title: Head gasket question relevance 2 or 3 hole
Post by: DieselVanagon on January 09, 2010, 10:10:00 pm
According to my part supplier the AHU TDI head gaskets variations are identified by holes??. There is a 2 hole version with 1.5mm thickness and a 3 hole version with 1.6mm.
Where are these identifying holes, how much does it matter to get the right one?
Title: Re: Head gasket question relevance 2 or 3 hole
Post by: fairweather on January 10, 2010, 06:35:33 pm
You can get 1,2 or 3 holes. It depends on the amount of piston protrusion above the block, The specs are in the Bentley.
Looked it up:
For 1Z/AHU
.91-1.0 mm  1 hole
1.01-1.10mm 2 hole
1.11-1.2mm   3 hole
I used a 25$ digital caliper and confirmed with a micrometer though the mic is overkill for this. Make sure the piston is at absolute TDC.
Post by: burn_your_money on January 10, 2010, 06:46:26 pm
The ID holes are on the front of the engine in front of cylinders #2 and #3. It's a tab sticking out. Usually you can go by what is on there but the proper way is to measure it. Mechanics are lazy and will just swap on a #3 gasket (thickest)
Post by: DieselVanagon on January 13, 2010, 09:19:41 pm
Thanks for the advice. I will measure to confirm what I need to order. The tab on mine has one small hole and one oblong.
This website has great pictures of the differnet head gaskets.
http://www.ipco-inc.com/ (http://www.ipco-inc.com/)
