Engine Specific Info and Questions => IDI Engine => Topic started by: 94GolfTD-MK on October 20, 2005, 04:16:00 pm
Title: Anybody have a pic of a boost gauge install?
Post by: 94GolfTD-MK on October 20, 2005, 04:16:00 pm
Looking for a pic of where you T the boost gauge line :)
Thanks
Mike
Post by: Maarten on October 21, 2005, 12:21:45 am
Between the line from the intakemanifold to the injectionpump is best of the pressure that the engine recieves, or in the line to the wastegate is for checking the pressure that the turbo is acutally blowing.
Post by: veeman on October 21, 2005, 06:59:17 am
As Maarten said, I opted for the thin vacuum line between the intake "elbow" and the pump.  It seemed a lot easier than trying to tee into the thicker wastegate line on the turbo.
Not sure what gauge you'll be using, but consider using one of the new tee's that has the built in restrictor to eliminate needle bounce.  I've got one and it works great!
There's more info here....
http://www.newsouthperformance.com/fitting.htm
and a bit of discussion here...
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1809
