Engine Specific Info and Questions => IDI Engine => Topic started by: professor on December 26, 2009, 03:01:26 pm
Title: timing 1.9D N/A 1Y motor????
Post by: professor on December 26, 2009, 03:01:26 pm
i already search in this forum and i didn't found the pump timing for the 1.9 N/A... i found for 1.9TD, 1.9TD and 1.6 N/A. anyone knows the mm's for the 1.9 N/A?
Title: Re: timing 1.9D N/A 1Y motor????
Post by: the caveman on December 26, 2009, 09:02:50 pm
I initially set mine at 1.00mm just to see. Was okay and started fine cold but real noisy. I then retarded it  without the gauge to what i thought was maybe .90 but after checking was at .85. Ran okay at both except harder to start cold. Now have a Giles pump set at .95.
Post by: professor on December 27, 2009, 05:09:57 am
thks
1.00mm it's noisy and 0.95mm don't have noise?
what's a giles pump?
Post by: the caveman on December 27, 2009, 07:00:23 pm
Yes quieter now with the timing at .95 Check out http://www.performancediesel.ca/. (http://www.performancediesel.ca/.) His pumps are all over here. I'm still tweaking the fuel screw, but i figure i now have about 85-95 hp compared to the 75 it had before and the 60 that my original 1.7 had.
