Engine Specific Info and Questions => IDI Engine => Topic started by: 54321chris on November 28, 2009, 08:55:04 pm
Title: Newb crank pulley question
Post by: 54321chris on November 28, 2009, 08:55:04 pm
Does the accessory pulley portion of the crank pulley come off separately with the removal of those four little bolts, like on a TDI?  Or do I have to take the center bolt out of the crank pulley in order to get the thing off?  I have a 1.6 GTD, I think an SB engine code.
Title: Re: Newb crank pulley question
Post by: Vincent Waldon on November 28, 2009, 09:27:43 pm
Yup, leave that centre bolt alone.  ;)
Remove the 4 hex bolts, tap with rubber mallet.  A bit of PB Blaster overnight can help if there's a lot of rust.
Post by: 54321chris on November 28, 2009, 10:03:42 pm
Thanks!  I'll give it a shot.
Post by: Black Smokin' Diesel on November 29, 2009, 08:39:28 am
Yeah the ACC. pulley can be a real PITA to get off if it's never been removed. I ended up having to pry one off. Really not the best thing to do.
Post by: 54321chris on November 29, 2009, 07:17:43 pm
Got it!  Thanks fellas.  Now to find someone with IP timing tools...
