General Information => General => Topic started by: 2strokesmoke on November 26, 2009, 09:41:47 pm
Title: water pump connections
Post by: 2strokesmoke on November 26, 2009, 09:41:47 pm
Hi guys,
I'm installing a new water pump (complete assembly-pump and housing) which
I purchased from autohausaz.
After mounting the pump, I was installing the hoses and found that one of the hoses connections was the wrong size.
My old pump had 3 connections:
1) lower rad hose
2) bypass hose to cyl head 1.032" dia
3) hose to metal pipe for heater and expansion tank  .870"  ************
NEW PUMP Graf #PA579  autohausaz #037121010a
1) lower rad hose (is the same)
2) bypass hose to cyl head 1.032" dia (is the same)
3) hose to metal pipe for heater and expansion tank  1.032"  ***********
So the new pump has a larger outlet going to the metal pipe. 1.032" instead of
.870" like my old pump.
Everything else appears to be the same.
My question is--
Can I use a different hose,to make this water pump fit my 82 VW pickup
with 1.6NA ?
I was really hoping to finish the truck this weekend- sending the pump back
to get another one-will delay this project for a week.
Ant Ideas what the new pump is for and what model VW I could order a hose for
to make this work ?
I opted to change the entire pump assembly,because mine was quite nasty=corroded,frozen bolts,ect..
I hoping the pump is for a later model,and I can just use a different hose.
I'm anxious to get this truck going agian.
Thanks in advance, Mike
Title: Re: water pump connections
Post by: fatmobile on November 26, 2009, 10:19:19 pm
The A2s have a larger hose coming from them.
 You might be able to use a MK2 hose,...
 but I can't remember if the metal coolant pipe in the MK2 is bigger also.
Post by: boxer246 on December 02, 2009, 04:00:20 pm
Ok I'm pretty sure i ran into this problem a few years back.  The hose you need is the one on this page the last one pictured.
http://www.germanautoparts.com/Volkswagen/Jetta/Cooling/118/1 (http://www.germanautoparts.com/Volkswagen/Jetta/Cooling/118/1)
If you have an oil cooler then its different entirely.
Let me know if I got it right.
http://www.germanautoparts.com/images/7607a6e2d4336303132313836303/f (http://www.germanautoparts.com/images/7607a6e2d4336303132313836303/f)
