Engine Specific Info and Questions => IDI Engine => Topic started by: brandon5 on November 26, 2009, 09:03:25 pm
Title: mk2 1.9 td swap. pics and questions
Post by: brandon5 on November 26, 2009, 09:03:25 pm
Ok so im currently doing a 1.9 swap and i have a question about the one fitting on the back of the engine. I ended up swapping the t3 turbo and manifold to the 1.9 and this fitting is different.
Sorry for the sh!tty celly pics and the noob questions.
(http://img267.imageshack.us/img267/9315/img00242b.th.jpg) (http://img267.imageshack.us/i/img00242b.jpg/)
Is there anything i can do to make the fitting off the 1.6 engine work? or can i use a rubber hose?
Also, There was something attached to the small stock turbo that i have no idea what it is...
(http://img267.imageshack.us/img267/3194/img00239.th.jpg) (http://img267.imageshack.us/i/img00239.jpg/)
Once again sorry for being a noob. Do i use it with my t3? or take it off.
And there are wiring connections at the other end for it.
(http://img262.imageshack.us/img262/597/img00240.th.jpg) (http://img262.imageshack.us/i/img00240.jpg/)
Alright sorry for all the bad pics... Hopefully this makes a little sense, im also swapping the complete mk3 harness with the motor aswell as the dash.
The car
(http://img338.imageshack.us/img338/996/img00234.th.jpg) (http://img338.imageshack.us/i/img00234.jpg/)
(http://img69.imageshack.us/img69/7418/dscf0006gl.th.jpg) (http://img69.imageshack.us/i/dscf0006gl.jpg/)
(http://img228.imageshack.us/img228/2482/gettacopy.th.jpg) (http://img228.imageshack.us/i/gettacopy.jpg/)
Thanks again! I just wanna finish this swap.
Title: Re: mk2 1.9 td swap. pics and questions
Post by: GEE-BEE on November 26, 2009, 10:14:02 pm
See the oil return drain thread for info on the drain..
You can get a adapter and hose from ebay as a kit..
Picture two is the wastegate control valve..
Gee-Bee
Post by: brandon5 on November 27, 2009, 05:59:49 am
So do i need that wastegate if i have one on the manifold already? Is there any alternitive for the return line? Can someone give me a link to ebay?
Thanks 10000000
Post by: brandon5 on November 27, 2009, 11:55:55 am
Bumpppp i wanna get this swap movinnn
Post by: burn_your_money on November 27, 2009, 02:27:36 pm
You could get a 1.6TD oil pan, plug the hole in the block and use the stock 1.6TD oil return line.
Correct me if I am wrong but I don't think that the stock line would be long enough
The T3 already has it's own wastegate. What you have in the picture is useless to your swap
Post by: brandon5 on November 27, 2009, 08:58:01 pm
Alright cool thanks for the reply. What would i do with the wiring and the tubing then? just plug it?
