Engine Specific Info and Questions => IDI Engine => Topic started by: MouseGTD on November 14, 2009, 08:24:48 am
Title: 1.6 td questions (head studs, metal HG, clutch)
Post by: MouseGTD on November 14, 2009, 08:24:48 am
i wanna upgrade my 1.6td head gasket to a metal one from the AAZ, is this just i direct replacement? theres also a lot of talk on here about ARP head studs, what are the benefits of using these over standard head bolts? also is it true that the ARP studs for the 1.6td are the same as those for the cosworth engine like these ones?... http://cgi.ebay.co.uk/ARP-Cosworth-YB-Head-Stud-And-Nut-Kit_W0QQitemZ280406831366QQcmdZViewItemQQimsxq20091008?IMSfp=TL091008147001r4360 (http://cgi.ebay.co.uk/ARP-Cosworth-YB-Head-Stud-And-Nut-Kit_W0QQitemZ280406831366QQcmdZViewItemQQimsxq20091008?IMSfp=TL091008147001r4360)
also is there any oe VW clutches that are an up grade to the standard one found on the 1.6td?
thanks for any help ;D
Title: Re: 1.6 td questions (head studs, metal HG, clutch)
Post by: Black Smokin' Diesel on November 14, 2009, 09:30:21 am
The metal headgasket is a direct fit on hydraulic engines (86+). The main advantage of ARP studs is that they are reusable. Yes they are the cosworth studs.
I've heard of people using a 1.8 8v clutch disc with a 16v pressure plate with good results. You can't use the 16V clutch because it's for large spline 16v trannies.
Post by: MouseGTD on November 14, 2009, 10:38:48 am
cheers mate 8)
just another thing, if i upgrade to the AAZ hg are the thicknesses the same (is a 2 hole fiber gasket the same thickness as a 2 hole metal hg?), and where do i look to see how many holes my head gasket is?
Post by: Vincent Waldon on November 14, 2009, 11:50:14 am
1) Not exactly... the FAQ links to a thread with all the numbers.
2) The notches/holes are visible at the front of the gasket near the coolant flange, but in reality the best approach is to measure piston protrusion once you get the head off...far too many folks just throw a 3-notch gasket and hope for the best. ;)
Post by: MouseGTD on November 14, 2009, 12:35:34 pm
unfortunately i don't have the time to be waiting until the head is off before finding out which head gasket i need. the car is my daily driver and i'll only have a weekend to get it sorted and my local motor factors can only supply parts like this through the week as they have to order them in so i'll have to go off the holes in the gasket that is already on it.
Post by: aidan on November 15, 2009, 05:58:36 am
Have a look on tdiclub about the arp bolts, there is a few instances of failures. Worth looking at the arl head bolts (oem off pd150), might work out cheaper and more reliable
Post by: MouseGTD on November 15, 2009, 11:56:03 am
isn't the 8v clutch disc 10mm smaller than the 16v pressure plate though? would this cause a problem?
Post by: carrizog60 on November 15, 2009, 12:09:48 pm
any upgrade comparing to the 1.9 ones?
Post by: Black Smokin' Diesel on November 16, 2009, 08:58:10 am
Nope they are both 210mm.
