Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: avocado on November 10, 2009, 07:43:24 am
Title: Losing Prime again and again....MTDI AHU
Post by: avocado on November 10, 2009, 07:43:24 am
Hi
I put a AHU in a Suzuki Sidekick.  Bought amanual pump from a fellow on here and the little truck runs great!  Well...most of the time.
It seems to lose prime at really weird times.
I recently put a clear fuel line (  5/16") between the fuel filter and the pump in order to see what the hell is going on.  I have found that sometimes after sitting the fuel line is completely empty of fuel.  I cannot figure out where the air is coming from...all lines are tight and new.
I was wondering if the fuel is just pulling out of the line (air coming from the IP side after shutdown?) and going back into the tank.
Should I put a check valve in the line at the tank to make sure fuel is only going to the engine and not back into the tank?
Title: Re: Losing Prime again and again....MTDI AHU
Post by: gldgti on November 10, 2009, 03:46:04 pm
check the injector return lines, and other return lines. when swtiched off, it will allow air in and all the fuel will drain backwards.
Post by: avocado on November 11, 2009, 10:20:14 am
Wouldn't it be easier to just add a check valve?
The thing is that I remember having put my return line into the tank at a pretty high level, so it may be sucking air from back in the tank...
Title: Losing Prime again and again MTDI AHU
Post by: D.Loops on December 02, 2009, 08:17:24 pm
air in the fuel would be a problem for starting must be sucking air from somewhere or fuel could be leaking back to tank could try a non return valve?
Post by: westyventures on December 02, 2009, 10:57:22 pm
Check the pump shaft seal.
