Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: the caveman on November 07, 2009, 02:04:51 pm
Title: Setting IP with dial gauge -Specs found !
Post by: the caveman on November 07, 2009, 02:04:51 pm
This is a follow up to a post i did in troubleshooting. i am have problems getting a rebuilt pump to run on a 1997 passat. I am looking for any reference as to what i can set the pump at with a gauge [like am IDI] before running it and setting the timing with my vag-com.
Title: Re: Setting IP with dial gauge
Post by: the caveman on November 09, 2009, 04:07:19 pm
Well i will  be certain to post what i find.
Title: Re: Setting IP with dial gauge Specs found !
Post by: the caveman on November 13, 2009, 02:40:24 pm
Okay i won't mention here how i got it running BUT i did find a tech bulletin for my question. Tech bulletin group 23 #97-03 from august 15 1997 mentions that it can be set at .7mm + or - .05 mm. Problem is that the size of the fitting on the pump isn't the same as an IDI pump. The early pumps [and the tool] have a thread of 8mm with a 1.0 pitch where as the TDI [at least the 1Z passat i was working on ] has a thread of 10 mm with a 1.0 pitch. I will make a tool  adaptor in the future , but at least there is some sort of spec for it.
See my post in troubleshooting for the " fix "
Post by: burn_your_money on November 14, 2009, 10:26:09 am
Problem is that the size of the fitting on the pump isn't the same as an IDI pump. The TDI has a thread of 10 mm with a 1.0 pitch.
All of the TDI pumps we have in the shop use this style.
Title: Re: Setting IP with dial gauge -Specs found !
Post by: the caveman on November 14, 2009, 10:44:13 am
Which stlye are you talking about ? the fitting for the gauge tool ?
BTW how's my pump coming along ,if you actually got my old one  yet ?
Post by: Baxter on November 14, 2009, 01:05:42 pm
Brake line fittings are M10x1.
Post by: Vincent Waldon on November 14, 2009, 01:08:20 pm
...as are oil pressure and coolant temp sensors.  An old brake fitting / sensor and an 8mmx1 tap builds you an adapter.  ;)
Post by: burn_your_money on November 14, 2009, 07:19:16 pm
Your pump is almost built. It should be on the test stand on monday.
Post by: the caveman on November 15, 2009, 07:21:51 am
Vincent and Baxter-thanks. I may fit one up for the future. But i/m wondering if i'll ever run into such a problem again. Of course i shouldn't talk too soon, there will probably be one in this week.
And Tyler-AWESOME !
Post by: Tintin on December 09, 2009, 08:52:31 pm
I do it often in the past with a dial indicator, usually between .70 to 1.00mm
The adaptor for TDI already exist in some kit, I see it on Ebay.
