General Information => Troubleshooting => Topic started by: jettabrendan on October 13, 2009, 10:29:36 am
Title: not much heat
Post by: jettabrendan on October 13, 2009, 10:29:36 am
My mk2 has no heat, both heater hoses get hotl so I'm assuming the heater core isn't plugged. Blower works great, but the air is barely warm. Sorry for vague info but its all I got.
Title: Re: not much heat
Post by: rabbitman on October 13, 2009, 01:25:51 pm
I'm not an mk2 expert but I've heard the "doors" inside the heater box can leak and mix hot and cold air, do a search there's been lot's of talk about it. ;)
Post by: maxfax on October 13, 2009, 05:45:54 pm
Rabbit man has got it..    THe blend doors are essentually a piece of sheet metal that look like swiss cheese..   Then they are coated with foam rubber..   The foam rubber turns to dust and the swiss cheese doesn;t divert air so well..   An easy fix is to remove the lower duct work and reach up in there and cover the thing with duct tape..  Although the duct tape doesn;t last so long..  I opted to glue pieces of plastic to the door (sides cut out of an antifreeze jug no less).. Works dandy....
Post by: jtanguay on October 14, 2009, 09:59:54 am
i'll third the blend door problem. after my heater core blew the anti freeze turned the foam into dust. if you want something a little more permanent and long lasting, use the aluminum tape used for duct work. i myself have used foam i bought at the dollar store and some 3M spray adhesive, but we'll see how long she lasts! :) check out my thread in the FAQ (http://www.vwdiesel.net/forum/index.php?topic=20448.0)
i would also recommend flushing out your cooling system as that really helped me out! (much much more heat!)
Post by: JBG3 on November 02, 2012, 07:30:43 am
I have pics to relate to this issue, I just got into this extensively-
Heater doors foamless and swiss cheesy-
(http://i1217.photobucket.com/albums/dd387/tinworm2/86%20VW%20Jetta/008-2.jpg)
Post by: TylerDurden on November 02, 2012, 10:32:50 am
+1 on the metal duct tape.
Putting the tape on is a PITA, but much easier than pulling the airbox. It helps if you have dainty hands.
The door in the back is the hot/cold control.
(https://lh5.googleusercontent.com/-ZAmamXW7pYY/TUgU4-jtufI/AAAAAAAAAV0/A6VJojTK0Wo/s640/ventDoors_withFoam-IMG_0743-ALT.jpg)
You may have noticed dark flecks of debris coming out of your vents - that's the old foam. I'm not sure how much gets stuck in the core, but I bet it's significant.
Post by: srgtlord on November 02, 2012, 12:05:04 pm
I used lots and lots of duct , regular duct tape 4 years ago....
Post by: ToddA1 on November 03, 2012, 10:09:54 pm
That looks like the same heater box that's on my B4 Passat.
http://forums.tdiclub.com/showthread.php?t=364026&highlight=Heater+box
-Todd
Post by: TylerDurden on November 04, 2012, 11:41:44 am
That looks like the same heater box that's on my B4 Passat.  http://forums.tdiclub.com/showthread.php?t=364026&highlight=Heater+box
It looks the same to me. Kudos on that b*tch of a job.
Was there foam stuck in the fins of the core, or had most of it blown out the front?
Post by: ToddA1 on November 04, 2012, 01:22:55 pm
The core is before the foam, so the foam blows out the vents.
-Todd
Post by: wdkingery on November 07, 2012, 08:06:33 pm
Shut up Yall mean I could have considerably more heat!? 1985 I bet I got a case of the cheeses too!
Post by: quanstrom on November 07, 2012, 08:42:20 pm
I have an '85 which I bought without noticing the inlet and outlet water hoses to the core "teed" together.  It was a cold ride home that night...
I pulled everything apart and used sort of a duct tape method to restrict all air through the holes last year.  The car is capable of cooking a pot roast in the back seat if the blower switch is on "4" now.
Post by: TylerDurden on January 02, 2013, 06:43:45 pm
I had a blinding flash of the obvious today...
My 89NA Jetta was taking a long time to warm up and get heat to the cabin. (I've done the tape on the airbox doors and flushed the core.)
But, while running a can of cleaner through the IP, I realized the radiator fan was running because I had the selector in the Defrost position. The AC has not worked since I bought the car, so I took the condenser out last year when I loaned the car to my pal in Miami, to let as much air flow to the radiator as possible. Well the rest of the AC stuff is still there, including the wiring that energizes the fan when the selector is in any AC position, including defrost. (Strangely, the AC relay normally on the fusebox is missing.)
My solution was to undo a connector in the engine-bay (no need to get into the dash mess). The double connector by the battery has R/W and G wires. Disconnecting that retains the thermostatic switch function for the fan. In the summer, the connector can be re-connected to allow forcing the fan on for extra cooling.
My other 1.6s have piping hot air from the vents: ~150F, this car only about 110F.  Oh well, I doubt I'll replace the core... I don't plan on keeping this car after the winter passes.
Post by: damac on January 02, 2013, 06:50:30 pm
I had to do the heater core on my 85 last week, getting dangerous to drive without one and cold :)
Mine was just like the pics, no foam on doors, worn out bits on vent flappers.
I decided to take the route of taking the dash out and thats the way I would do it in the future even though I have seen people mention doing it with it installed.  This way I could easily move things around and refresh all those doors.
I don't have ac on my jetta, but it was rather easy to get to all bolts with a small ratchet/socket setup.
Post by: tyb525 on January 02, 2013, 07:21:18 pm
So if my vents are open with the fan on and cold air blows out of them even when I'm stopped, and hot air blows out of the dash vents, is this because I'm missing the foam?
Post by: TylerDurden on January 02, 2013, 07:31:30 pm
IIRC, Mk1 vents at the end of the dash are always fresh-air, unless modded by the user.
Post by: tyb525 on January 02, 2013, 07:42:19 pm
Should fresh air blow out of them when the fan is on, and the car isn't moving?
Post by: theman53 on January 02, 2013, 07:44:45 pm
yes
Post by: 8v-of-fury on January 02, 2013, 08:48:45 pm
wuuut? LOL. If the fan is on, air is a blowin'. Looks like a Rabbit in your picture, if so the outer most dash vents are out side air always. Unless you close them personally at their respective locations, whatever temp air is outside will blow in. Regardless of dash selection.
Post by: TylerDurden on January 03, 2013, 04:31:29 am
Some older cars had passive fresh air vents. Not VWs..
Post by: 8v-of-fury on January 03, 2013, 08:08:18 am
As in, open vents to the atmosphere? Yes, I am aware. Are you aware you are logged in to a Volkswagen Site?  :P ;D ;) LOL jk jk.
Post by: nwcali6 on January 03, 2013, 08:13:06 am
My 96 Passat also has this problem, I've not yet yanked the dash apart, Instead I put in a 190 thermostat.  It made a noticeable difference and was much easier.  (my old one was only getting to about 160 before it would open though).
Post by: tyb525 on January 03, 2013, 02:52:57 pm
Hey I've only had the car for 3 months and never owned a VW before that. Pretty much everything I know about it cam from this and other forums or the Bentley.
My truck has passive air vents, air doesn't blow out of them if I'm not moving, even if the fan is on. I didn't know if the rabbit was supposed to be that way or not.
Post by: TylerDurden on January 03, 2013, 03:07:54 pm
One very cold winter I was driving about 600mi in a rabbit and the vent seals were leaking badly... I pulled the dash vents out and stuffed my spare socks into the openings to stop the drafts.
Post by: 8v-of-fury on January 03, 2013, 06:38:22 pm
Socks! NICE.
Post by: TylerDurden on January 05, 2013, 06:20:22 am
Ja, vacation clothes put to noble use.
Sometimes I like the MK1 setup... everyone in my family likes it much warmer in the cabin than I do, so I point that cold vent at my face. Who needs fancy passenger/driver heat controls?
Post by: air-cooled or diesel on January 13, 2013, 09:12:34 am
that picture helped alot, and wasnt that difficult. 2 8mm nuts and the front cover comes off(with some work). i used 3M super adhesive, it seemed to dry hard so you could tape(al, or ss)on one side as back door is impossible to get to. tape both doors and you have heat, lots of heat! marking door w/a marker while practicing helped me place tape on final attempt. i didnt tape all the way to the edges so tape wont peel off due to repeated movement of doors.
Post by: nwcali6 on January 15, 2013, 07:39:51 am
  Volkswagen touts their "German engineering" on TV now...  My 96 TDI has this problem, and I just received a 94 gasser (for free) and it does this also.  Foam blowing out the vents.  I also know older VW that do this.
  Has this never been addressed as a recall issue?  Slapping a piece of foam over a hole (that doesn't need to be there) and calling it good for that long is so "yugo" like.  I doubt even a Yugo would have done it..
  So why no recall?  Where did the consumer fail in making this very repeatable issue (happens on all of them I think) known?  Not to mention the crap door handles...
Post by: TylerDurden on January 15, 2013, 08:17:25 am
I rekon recalls are for safety issues, warranty issues are for defects occurring during the covered period... 96 would be >16yrs?
Post by: nwcali6 on January 15, 2013, 09:04:08 am
When it comes to safety I don't think manufacturer defects apply the same.  I consider a almost 100% failure rate on a defroster a manufacture defect, and I could really care less if its 30 years old... It fails because its a bad design...
Post by: tyb525 on January 15, 2013, 04:13:33 pm
The Germans will tell you, they did it on purpose just because they can ;D
Post by: pvc4life on January 16, 2013, 02:01:14 pm
This must by why my Jetta's heater doesn't work worth a damn...
Post by: air-cooled or diesel on January 18, 2013, 01:58:50 pm
for my car it wasnt that difficult to do
