Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: mtnbob on October 12, 2009, 08:50:03 pm
Title: How difficult is it to switch out a 1.9TDI for a 1.6 N/A ?
Post by: mtnbob on October 12, 2009, 08:50:03 pm
Considering a unique vehicle that has a 1.6 N/A in it. Would like to upgrade the power to a 1.6 TD or a 1.9 TDI. I have heard that you can put in a 1.9 without all of the electronics, using a different setup for the pump. Is this very hard to swap over? Any suggestions appreciated.
Title: Re: How difficult is it to switch out a 1.9TDI for a 1.6 N/A ?
Post by: mystery3 on October 13, 2009, 11:59:18 am
This should answer a few questions:
http://www.vwdiesel.net/forum/index.php?topic=6427.0
Search mTDI for any other info.
Post by: jtanguay on October 16, 2009, 09:27:19 am
if its a mk1, then you'll need the mk1 passenger side mount.  it's been done before with the ALH so you should be good to go!
Post by: drrtybyl on October 17, 2009, 08:51:10 pm
You just need to mod the passenger side engine mount and belt cover mounting plate so that it doesn't rub the timing belt, IM shaft wheel, etc.
(http://lh6.ggpht.com/_nERFi5LkZKk/Sj7mhGurr5I/AAAAAAAAALg/1AHmFA5Ux3M/s512/timing%20belt%20and%20engine%20mount.JPG)
Above taken from this thread (http://forums.tdiclub.com/showthread.php?t=249324).
