Engine Specific Info and Questions => IDI Engine => Topic started by: Doakster on September 04, 2009, 05:45:32 pm
I'm doing the clutch this weekend, and I don't have my bently manual with me. Could someone please give me the following torque specs.
-Pressure plate to crank shaft bolts.
- Flywheel bolts.
- Transmission to engine bolts.
- Motor mount bolts.
- Drive shaft flange bolts.
I would great appreciate the help.
pressure plate to crankshaft 22 ft-lb
flywheel to clutch pressure plate 15 ft lb
transaxle to engine (M12 bolt) 55 ft lb
there are 8 different specs for the motor mounts so let me know if its rubber or hydraulic mounts.
driveshft to flange 33 ft lb
hmmmm...I'm gonna say they are rubber. By the way I owe you one, you're a life saver.
I'm not a life saver, I am not small round and fruity
engine front mount to engine is 33 ft lb
engine front mount to rubber center bushing through bolt 37 ft lb
rear right engine mount to rubber center bushing (M10 bolt) 59 ft lb
rear right to to bushing bracket or engine (M8 bolt) 18 ft lb
loose nut behind the wheel 26 ft lb with left handed metric adjustable
